Doug7L
Club Member-
Newbury Park, CA
Se7en
Caterham S3
GONE
littlehighland6 started following Doug7L
Doug7L started following WTB Duratec to T9 bell housing, hydraulic and Zetec Raceline Wetsump repaired
This sump was damaged by pothole. Repaired by welding. It held oil but still seeps. Someone with talent and patience might be able to weld it properly. Only the parts in the photos are included and I no longer recall if this is correct oil pickup. Sold as is. $150.00 plus actual shipping cost. Located in Newbury Park CA Doug 805-402-1225
Doug7L replied to Doug7L's topic in Parts For Sale / Wanted
Thanks. -
Thank you. Looking to source once in the USA to avoid the tariffs. I will buy from the UK if needed. Doug -
As stated I am looking for a T9 to Duratec bell housing. Used or new. doug@tidsales.com 805-402-1225
13" Kodiak Lightweight three piece wheels
Wheels still available. Reasonable offer. -
Send your zip code and I can get a price. Define what you mean by 'too much'. I used them with my 175 hp 1250 lb Seven. The main issue is getting the slicks up to temperature. This is because the car is so light. Take it easy for the first lap or two. They really liven the car up because of the lower rotational inertia. You are welcome to email me direct. doug@tidsales.com -
Still available . New price $1000.00 plus shipping. Doug@tidsales.com -
The wheels are about 10lbs each without tires. Cycle wings on the front. No issues with clearance. My car was a 2001 build S3. De Dion rear suspension with Sierra Diff. -
Back to the top. -
Question on Size. DIMENSIONS ± FRONT REAR OVERALL WIDTH 7 ¾” 8 ¾” Bead /Tire width 7” 8” Back spacing 4 5/8” 5 ¼” If I did my calculations correctly that gives them about 19mm offset in front and 22 mm in rear. Positive offset. Please do your own calculations to verify they will fit your car. $1500.00 Price lowered to $1200.00 Doug 805-402-1225 see also: https://www.californiacaterhamclub.com/forum/caterham/for-sale-wanted/38543-13-kodiak-3-piece-wheels A selection of spacers are included. -
Longer studs are easy to do. Too wide a slick is harder to get warmed up because the cars are so light. I needed at least a full lap and that is if the weather and track are not cold. -
Kodiak can make the size and offsets you need. https://www.kodiakracingwheels.com/ You might also look at Jongloed. https://www.jongbloedracingwheels.com/wheels -
What doesn't fit? I used 1/8" spacers on the rears so the tires would not rub on the Watts links. -
DIMENSIONS ± FRONT REAR OVERALL WIDTH 7 ¾” 8 ¾” Bead /Tire width 7” 8” Back spacing 4 5/8” 5 ¼” If I did my calculations correctly that gives them about 19mm offset in front and 22 mm in rear positive offset. Please feel free to correct my calculations
