nop, its Math...
with a 99mm Stroke 7,600 is exact 25m/s Pistonspeed.
This is what every piston manufacturer recommends as the maximum. The specific material pairing of cylinder wall and piston determines this value and, of course, the oil. These are microphysical areas that are the way they are. If your tuner says he can turn 9200 with 99mm stroke, he has simply found the solution that all Formula 1 manufacturers have been looking for years... Because with that, your engine would have reached 30m/s. In Formula 1, engines are driven at up to 28m/s, but at immense cost in terms of materials and production. You can certainly turn more than 25m/s for a short time, but you have to be aware that every second of this speed causes real wear!
It's easy to throw out a few numbers at the regulars' table, but if you're intensively involved with engines, or even study engine construction, it's a completely different story.
Cosworth Duratec gives a maximum of 9000 RPM for a 2 litre engine with 83,5mm stroke. And with the 2.3/2.4 engine it is 8200. This is again in line with 25m/s and is the only serious statement!
Everything else is not to be taken seriously in my eyes, unless you want to bore and ream more often.
