savagete2860
I didn't realize WDH's were a no-no on aluminum trailers, that is good to know. Low spec steel enclosed 7x14 trailers seem to range from 2k-2.5k lbs, so with the seven Id still be under 4k and have the option of a WDH, so I think that might be my preference. Having never towed, WDH and sway control sound like they would be really nice to have to avoid white knuckling every trip. Good to hear you haven't really felt the need for it with you setup though, this might be something I hold off on. Hitch wise, I am open to any and all recommendations. I am guessing something that allows the ball hitch to be higher or lower is ideal to try an level out weight - if I don't go the WDH route, I will probably get something like the regular weight safe hitch so I can adjust the ball height and see the tongue weight. I heard the gauges crap out after awhile, but as soon as I figure out where and how I will load the trailer, I don't think I would even need to look at it anymore. Thank you for your $0.02. At this point I think I would only consider a WDH if I got with an enclosed trailer. According the the dash I am at ~17 MPG in the Frontier, granted none of that is highway. Thanks - and yeah going with the Frontier gives me significantly more options than the Maverick towing wise. You are echoing others, hold off on the WDH. Trailer wise, assuming enclosed, how should I plan to secure the seven? Should I consider something like this? https://www.etrailer.com/Car-Tie-Down-Straps/Erickson/EM58523-09162.html?
I am one step closer to posting in the tow rig thread. I picked up a Nissan Frontier. I will still need to pick up a trailer brake controller and install Nissan's tow mode button, but its ready to go for towing. Unlike the Maverick, it allows me to rent a uhaul trailer or buy my own. It weighs 4720 lbs with a full tank of fuel, and has a payload of 1292lbs. Other than the awful fuel economy, so far its a great truck. Next up is a trailer. I am still undecided on open vs enclosed, although still leaning enclosed. It seems like it would be wise to get some type of weight distribution/sway control hitch. From what I have been reading, if you're towing anything that is 50% or more the weight of the truck its a good idea. With an enclosed trailer, I am sure I will be at or north of 3000lbs. Is this something I should worry about? Anyone able to school me on these? Something like one of these: https://andersenhitches.com/products/weight-distribution-hitch?variant=42320407068715 https://www.equalizerhitch.com/products/e2-hitch/ Any other hitch recommendations? I am going to some trailer places in the coming weeks to hopefully have something by next month which is when my first HPDE is.
I agree and I think you are spot on. Bumping up to a mid-sized truck gives plenty of head room for towing. I think before I was really trying to fit a smaller truck into my use case but really that's probably not the best decision. Funny you mention the Frontier, that is the truck I was planning on test driving soon. I have read/watched mostly good things.
I haven't decided anything yet and probably won't buy anything until closer to spring. It still largely depends on the tow vehicle for me, which is what I need to figure out first. After this winter storm, I am hoping to checkout some mid-sized trucks to see if they fit in my garage or not. With something like the Maverick, I will likely end up playing it safe and going with an aluminum open trailer. If I bump up to something where trailer weight would be less of a concern, no question, I would go with a run of the mill aluminum 7x14 enclosed. Either option would be tandem axle with brakes. I am also leaning towards renting a Uhaul trailer at first (this might be too heavy for a Maverick though, not sure). Then I can spend some time checking out local trailer places and seeing what trailers fit the Caterham and can still hit appropriate tongue weights on my specific vehicle - assuming they let me figure that stuff out. However, if I smack the lotto, I am going to order one of these fancy custom trailers that have been posted.
I appreciate everyone indulging me. I am 100% over thinking all of this, to the point of analysis-paralysis probably. At the end of the day, I just want the smallest enclosed trailer that can fit my Caterham, its weather gear, aeroscreen, and a spare set of wheels. This thread has helped me understand that a 7x12 or 7x14 would probably work for my use, and looking around that should put me at a weight that is close to 3000lbs, give or take a bit going the aluminum route. @Vovchandr has been saying 5k lbs tow limit or more for a vehicle, and that seems to add up with what others have been saying, so I think I need to look at a midsize truck vs a "trucklette" like the Maverick, unless I 180 and go for an open trailer. I will continue to ponder... still open to more suggestions, comments or advice.
Good stuff @Timothy Keith-Lucas appreciate the photos. Guessing you pull the cars all the way to the front? I like the winch idea too. @bball7754 your trailer is awesome. I might have to at least try and get an estimate for something similar from them to compare to a standard enclosed trailer. @Davemk1 I 100% agree with everything you said and appreciate your anecdote. Tongue weight in the safe rage is a must for me - especially being new to towing. Your situation with needing to add things in front to hit 12% tongue weight make me a little worried about a v nose enclosed trailer where the car will probably be further rearward compared to an open trailer. @Vovchandr In your trailer photos your car looks pretty forward as well - have you ever measured your tongue weight? Are you able to hit 10%+ tongue weigh just by pushing the car forward?
What is not comfortable for long distances? Sway? Acceleration/braking? I think your setup is closest to what I will likely end up with, so if you're saying it kind of sketchy feeling for longer hauls I need to take that into consideration. Does your trailer have brakes? Any idea on weight? I'd love a picture when you are able to its not too much to ask. Like you said, a seven is almost 11ft, which only gives a hair over 1ft to move the car to adjust tongue weight. The reason I was asking about the V nose is that it will push the car back further than a non-vnose trailer, i think. I don't know if that is good or bad relating to tongue weight. A 14' obviously gives your more room to move backwards if needed, but would have the same problem moving forward V nose vs flat.
Again, I appreciate everyone comments. I have some good advice here. Tire ratings are on my list now of things to check. It might not make financial sense in the near or medium term, but time spent dealing with uhaul every track event and hauling around a questionable trailer doesn't seem worth it to me. I get people do this all the time, but it just seems like it would be a lot less stressful if it was my own trailer. I think that peace of mind is probably worth the financial trade off. Also, the biggest piece is I still like the idea of enclosed over open. I am confident a 7x14 enclosed would fit a 7 no issues. @Timothy Keith-Lucas you mentioned you are towing a 7x12 enclosed, how much left over room is there with your 7 loaded up? Is it a V nose? If you had to get a new trailer, would you buy that same size again if it was specific to your 7? How are you securing in your 7? Pictures here or in the thread @Vovchandr started (thank you, btw) would be super useful for me just to see as well if you had any. 7x12 sounds ideal but I want to make sure I am not going to be handicapping myself. I have been looking around on a few sites at trailers. Looking at https://www.stealthtrailers.com/enclosed-7-wide-cargo-trailers, it looks like bare bones aluminum v nose tandem axle 7x14s trailers can come in around 14-1500 lbs. Same setup in 7x12 are 1-200lbs less. I haven't weighed my car, but allegedly it is 1235lbs without doors or roof and 5 gallons of fuel. So I am assuming 1300lbs for car weight that puts me at anywhere from 2600-2800lbs. Throw on trailer brakes (no idea on weight of this stuff) and the actual straps (again, no real idea on weight here), etc, would a safe estimate be 3000lbs enclosed? I think so but I want to make sure there is nothing I am totally missing here. Is anyone here paying attention to tongue weight? Being new to towing, reading about sway I want to make sure whatever I get I can put in that 10-15% range. I am wondering if I can even get to 10% tongue weight if I go with a smaller enclosed trailer with a v nose with just the car loaded up. Anyways, assuming my assumptions are right, or at least in the ball park, towing load should be about 2800-3200lbs with a tongue weight of 280-320lbs (10%) to 420-480lbs (15%). Does that seems reasonable for any vehicle with a tow rating of 4k, electronic brakes, and also assuming payload can handle the tongue weight, passengers, tools, and a spare set of wheel/tires?
Thank you for the replies everyone, super useful stuff. I am still searching around for both trailer and truck. That was a good call out for checking the door width on 6x12s, a lot (all of the ones I was looking at) wouldn't fit my car. I am sold on tandem axles, it just seems worth the added safety and stability. Also I didn't call it out but I was planning on brakes on whatever trailer I get as well. I really REALLY wish those clam shell trailers that are all over the place in the UK were sold over here. I would snag one of those up in a second. I am guessing there isn't really anything comparable in the states, right? I haven't found anything but maybe I haven't looked everywhere. Maybe its worth reaching out to some custom trailer places and seeing if they could build something similar within a reasonable budget. I did some rough measuring, and a mid size truck can fit in my garage along with my 7, only just (door opening might be a problem and not enough height to jack it up for maintenance). I need to try and test it out in real life to see how much of a pain that would be along with the miserable gas mileage. With only doing a few events a year, it might make more sense to get the smaller, more economical vehicle, and deal with the downsides of an open trailer. I'm still pondering it all... I would love to see some more tow setups.
Thanks for the replies. Most of the higher tow capacity SUVs are just as wide as a mid size truck, so really don't think I'd go for those since I would like something with a bed as well for other purposes. Also a P car for a tow vehicle is out of the budget lol. I am still leaning pretty hard towards a maverick, I just need to make sure the trailer options would work with it weight wise. Also just to clarify, the Caterham will still be stored my garage, the trailer will be stored somewhere else. Thats one of the reasonsd I want to stay on the smaller side for the tow vehicle. Sounds like an enclosed 6x12 does fit a Caterham, its just a but of a squeeze. I would be fine with that, I think. I just want to make sure were talking enclosed and not an open trailer. Is that tight on the width side or the length side, or both? Anyone have photos of a seven in an enclosed 6x12 trailer and how its tied down? Lets say I end up with an enclosed trailer, what do I need to look for inside of the trailer? I am not looking for anything fancy other than loading in the car and making it secure. Should tie downs be in a specific, maybe non-standard place? How sketchy is a single axle, really? It looks like the 2nd axle usually adds about 600lbs. Is that worth it for safety? I never really towed anything so maybe I am ignorant but how often are tires really blowing out to cause issues? V nose is a good idea I assume?
savagete2860 started following Help picking a tow vehicle and trailer for my Caterham
I posted this on reddit's r/cartrackdays, but it was suggested to me to ask here as well which seems like a no brainer. My local track, PittRace, is closing and there are no tracks in comfortable driving rage. So I am looking at towing options now. To start, my home is NOT conducive to larger vehicles. I am on a very narrow one lane street and my house has about a 20ft long drive way that is just barely two cars wide and is pretty darn steep (backing a trailer onto my property is likely impossible or at the very least close to it). It leads into a "2" car garage, which really feels more like an over sized 1.5 car garage. My Caterham is currently parked in here along with my 2021 Subaru Crosstrek (tow rating = 1500#s). I generally work from home and share this vehicle with my wife as our daily driver. The tow vehicle will replace this. Given my space constraints and the primary use case, I am looking for something relatively small. The smaller the better with modern niceties of apple car play and heated front seats are top of list. I am looking at a truck at this point vs an SUV/Crossover/etc. Trailer wise, I don't know where yet, but it will need to stay off property. I simply have no where to keep one. My first thought was an aluminum single axle tilt trailer. That would let me get something like a Ford Maverick with the 4k tow package (this was my front runner for a vehicle) and my total payload would only be ~2k lbs. The more I read and look, the more I think I want dual axle for safety and enclosed would be nice on the trips that are further out where the weather might be questionable in route or overnight parking in sketchy parking lots. So what is the smallest size enclosed trailer that can fit an s3 Caterham? I have seen a few 7x14s, but I am wondering if a 6x12 would work? I think even with a 7x14 trailer, I could squeeze in under the Mavericks 4k tow limit, but being enclosed I am not sure how terrifying that would be to drive with the additional surface area on windy days/passing semis blowing me around. If I must, I think I can squeeze into a mid-size truck, but it will BARELY fit in my garage. So what say ye - what's a good truck/trailer combo for my use case?
I think it was a ford fiesta st. Turn 17 was catching a lot of people out that day lol. https://10fsphotography.smugmug.com/Pitt-Race-TNiA-10-15-2025/Novice The car community is totally gutted about this in my region. Shameless plug to push back even if the outcome is likely inevitable: https://savepittrace.org/ PittRace is an AWESOME place. Alan Wilson designed track, exceptional facilities, hosts everything motorsports related, drifting, karting, autocross, car shows, motorcycle racing etc. The owners were putting about $1m each year into the facility since they bought it I think 2010 or so from the original owners. The sale came out of nowhere and speculation is the owners were offered a boat load of money for a fire sale. The same developers supposedly also purchased an RV park and a golf course for a total of 2k acres. If it does become a data center it will likely be largest one in the world. If it can happen to a track that is doing great financially and owned by a couple who loves motorsports and are already extremely well off, you better believe it can happen to your favorite track.
I ended up at the track last week and it went great. Rocky Mountain Caterham sent me out a beefier "race" coil subloom that I ran. I don't know if it was the race subloom, cooler temperatures, or something random I tightened since last time, but the car ran great without any issues. Hopefully whatever the cause was it doesn't pop up again. Aside from just going over the car 100 times the changes were: - Race coil subloom - Newer Ford plugs - Swapped to another (aftermarket) TPS I will post an update if it pops up again, but hopefully this thread slowly gets pushed down never to be surfaced again.
@slowdude Yeah that does sound different than mine. I can drive my car for short or extended periods of time with no issues. I couldn't even give you a description of why I had misfires at the track, it wasn't that hot and after the car cooled down a decent bit it had the same issues on the way home. Then 0 issues at all in 24 hours. I put on about 3k miles on the car in what has realistically been about 2 months, driving it almost every day it is nice outside, and the only time it had a true "this is totally broken" issue was the track day. @KnifeySpoonyWhat year is your build? I am guessing you are on the 9a4 ecu? Are you running with the green or black injectors? How you describe your car is in line with most owners with RBTBs threads I have read (blatchat mostly). Kind of why I was surprised my new car seemingly ran like a hunk of junk until I introduced more air. You mentioned somewhere your car idles at ~1100rpm. I am wondering if you have an older/different tune. I was told the car should idle between 900-1000 RPM and my car in closed loop will always target that. I have seen 1100 before and that when I added even more airflow which is when I first realized that seemed to fix my startup/idle issue. That was also only in open loop, and close loop pulled timing/fuel to bring it back to 9-1000rpm. My 420 is a new car assembled by RMC. Summer 2024 build (first year they started using the newer 9M4 ECU) that I took delivery off in late June of this year. Josh from RMC has been working with me to help troubleshoot the car's issues. Me being located in PA (not at altitude) and them being in CO makes it hard to really do much aside from send parts back and forth. Aside from the initial "sticky throttles" that are now fixed and mystery trackday misfiring that pretty much ruined the first track day, the issues have been tolerable (and now bandaid-able) to where I would rather keep the car in my possession to enjoy for the back half of the year before winter comes. If the car has the same misfire issues again on my next track day I think my only option at that point will be to ship the car back to CO. Related to the idle and start up, below are my throttle adjustments, RPM and STFT evaluated using Easimap. Baseline (hesitation and bogging issues) Throttle opening size: 6mm Airflow Rate: 5kg/hr Air bleed screws open or closed?: closed Cold idle RPM: 4-700 RPM Warm idle RPM: 900-1000RPM STFT correction at warm idle: pegging -20% Adjustment #1 (Started and ran great - maybe a weaker over run feeling and slower rev dropping between gears) Throttle opening size: 7mm Airflow Rate: 7-7.5kg/hr Air bleed screws open or closed?: closed Cold idle RPM: 1000 RPM Warm idle RPM: 900-1000RPM STFT correction at warm idle: +/-5% Adjustment #2 (This is what I am running now.) Throttle opening size: 6mm Airflow Rate: 7kg/hr Air bleed screws open or closed?: open Cold idle RPM: 800-1000 RPM Warm idle RPM: 900-1000RPM STFT correction at warm idle: -12 - -8kg/hr
Grounds seem good, I ended up not replacing the lambda sensor, new plugs, unknown about AFRs since I only have the narrow band. When driving, the car feels fine, pulls fine, etc. I actually think the plugs were likely so dark because of how rich it is/was at idle. I tried a new ECU and the issue remained so not an ECU problem. Is there a way to track fuel pressure in easimap? I don't even know if the car has that data available, i think its all just voltage based from the ECU, right? That is one area I feel like I am in the dark. As I mentioned before, the idle, startup, and tip in off idle issue is completely resolved if I introduce more air at idle, over the recommended settings from Caterham. CC say throttle openings at 6mm and pull 5-6kg/hr. If I pull 7kg/hr on each cylinder either via opening the throttle bodies more or from the air bleed screws, I have no issues at all in those areas. The car simply wants more airflow in that area for some reason. To be honest I am just going to run with it and not worry about it unless I ever hear back from CC that its a huge mistake and the car will explode. The bigger issue is how it acted on track and on the way home, where it would have no power for a decent period of time. I don't know what could cause that other than an electrical issue or something that is/was failing. I do kind of wonder if the pump was acting up. Visually all the connections and everything seem fine, and the car runs like a top on the street noodling around, hard on back roads, and even at autocross. What could even cause something like that which would magically fix itself by the next day with 0 change? I have absolutely no clue.
