savagete2860
Everything posted by savagete2860
  1. @CBuff did you drive in the rain there with no top?!? Great video!
  2. Yes I lucked out, big time. It was not something I want to do again. It was wet, I still had some steering angle while I pushed out onto the curb, and I gave it too much throttle and it just went out on me. All laps after that incident I big toe’d it through that complex of turns. Scary stuff…
  3. It was great to meet you and I am glad you made it back safely. You were buzzing around helping everyone during the event, and I am very thankful you were there and helped me tediously adjust my throttle stop. Also, after video review, I can confirm it was me that almost lost it on t12 after hitting the curb - it wasn't standing water like I said at dinner
  4. Here is a photo dump - the photographer had a favorite so you might have to do some digging but hopefully there are a few good ones of everyone. https://photos.app.goo.gl/Y6QakrBe1BBCiVoAA
  5. Bruce and Steve performing yet another surgery with the crew.
  6. @Croc I am Tim in car 68. This is my first year at this event and at NJMP. Great to see and meet so many se7en owners! I am also very happy the first mechanical failure I’ve had on track with my car (throttle cable) was around so many helpful people. You are all great! Can’t wait for tomorrow!
  7. I have toe plates and a camber/castor bubble level that would be interesting to compare as well. Anyone know where to get a road spec 420r radiator before Friday? Mine is leaking pretty good where they typically fail and was previously epoxied. Taking it to a local shop tomorrow but talking on the phone they didn’t seem like they had high hopes. I bought a radtec back in May and never opened the package because the epoxy patch worked great until this past weekend. Finally opened the radtec box and womp womp, they sent me the older style radiator.
  8. I am looking for lodging now, holiday in express is looking real nice (aka cheapest) but doesn't seem to be very trailer friendly. Assuming we can do trailer drop offs the day before by name dropping croc and garage 367, that might be the move here. Is there a time frame where they allow drop offs or will the track/security let people on premises all evening/night? I emailed the event organizer as well to ask. I am guessing I won't get out there until 8/9pm.
  9. Thanks! Signing up now. I removed the tech sheet link I posted to avoid confusion.
  10. Thanks for putting this all together @Croc, it'll be cool to see a bunch of se7ens in their natural habitat! I am signing up for both days soon... Are we signing up as Member Guest Registration w/Member in attendance or Member Guest Registration - Member NOT attending? Looking forward to the event.
  11. Thank you all for your help. TL;DR After too much trial and error, I finally have 2031 dated Schrotch Flexi 2x2 harnesses installed in my standard s3 chassis, lowered floors, and Tillet seats with sliders Caterham. Seats... I did not build my car, RMC did so prior to this ordeal, I have actively avoided removing the passenger seat even though I know there is a nice rock collection under there. I can hear every time I take a turn. On the drivers side seat there are bolts that come from the bottom that tighten into a captive nut on the tillet slider. I have removed this seat a few times - its a pain but not that a big deal. The passenger side is different. It has 4 of the most frustrating bolts I have ever dealt with and is pure misery. It has hex bolts going from the top of the seat slider into a nut and washer under the car. The sliders are interesting because there are bolts with a large head that mount the seat to the rail and then there are bolts on the slider with the same sized head that mount the slider to the car. This limits the slider movement because the bolt heads contact one another when trying to move the seat on the slider. This also means installing and removing the seats require bolts to be fastened/undone in a specific order or else you cant get to the bolts that need removed/installed. To remove, I had to slide the seat as far back as it would go and shove my hand between the bottom center of the Tillet seat and the bar running in front of where the seats mount. Its a very tight fit - there were a few times I thought my arm was stuck. If the rear slider and seat bolts didn't contact, the seat would have been able to go back a bit further and make this less challenging. At any rate, when my hand was in place holding the wrench I could feel my way to get a 6mm hex wrench in the bolt, hold it, and undo the bottom side nut with a 13mm socket. With the front bolts out, it allows the seat to slide far enough forward enough you can get to the rear bolts. Same process there there, but without hand and wrist pain gymnastics. This also required a helper for all bolts since you can't reach both the nut and the bolt. Putting the seats back in was reverse order. It is also 10x more difficult for the passenger side, primarily because you have to fully tighten the rear bolts and hope that the front holes line up. My pro tip for this is put the front bolts in upside down and leave them in place (if you can get them in place without falling out) and then do the rear bolts. Old Harness Removal This was pretty straight forward. 16mm wrench/socket for the stuff under the seat. Then the fun started. The outboard shoulder belts are long. In fact, they are too long to remove if you have a roll bar/cage with diagonals. I decided to cut the bolt but none of my cool power tools fit comfortably so I ended up using a little hack saw and sawed away for what felt a lifetime. New Harness Install For the install, I had to prep the harnesses themselves by removing the clip on end plates and replacing them with the b24 bolt in brackets. I also flipped the side lap belts to be in the pull up configuration since there is no room to pull down. I then used the existing belts to try and adjust the length to match. For installation, I followed what was on the car already (top to bottom) bolt head washer b24 plate b24 7/16" pivot sleeve car The factory setup had a wavy washer between the pivot sleeve and the bracket but I left that out for now. The sub belt mounts were a little different. The factory pivot sleeve is much taller than the replacements, so I also added some washers to take up more space. To deal with those bolts I had to cut, I replaced them with the 38mm 7/16 bolt from HMS https://www.hmsmotorsport.com/products/schroth-bolts?_pos=4&_psq=7%2F16+bolt&_psid=a425155e5&_ss=e&variant=47230555160676 It has a much shorter head than the factory bolts, fit under the roll cage bar and still leaves threads sticking out the side it goes into. Test fit and Finalize Install Once the belts were installed, I did some test fitting of the seat and sitting with the seats unbolts. This is the point I actually switched the side lap belt to pull up instead of pull down because I couldn't properly tighten the belts. Adjusting the sub belt with the cam lock took a bit of patience. I can get to the adjustment brackets at the Tillet seat opening so I didn't have to remove the seat at least, but getting in and out of the car over and over to make them right was not quick. This is one thing I am a bit worried about for instructors/passengers. It also forces use of the sub belt, which I found most people preferred not to use it when it was optional when just on the street. Once everything was adjusted, I bolted the seats back in. Final Results and Thoughts I do like the new belts functionally. They're easier to adjust and there is more room for clipping in my simpson hybrid s loops in. They also let me track at NJMP, so hard to argue with that for function. It is a completely other topic, but if NJMP wasn't mandating dated belts, I would have happily lived my life with the Caterham Luke harnesses. My particular harnesses have about 6 feet of excess belt for each shoulder strap. I tied them together and plopped it behind the seats for now. When tightened, the side belts have a lot of excess belt as well since I flipped to the pull up configuration and you lose the ability to pull extra belt out of the way. They can just be tucked somewhere so not a big deal though. If I was doing this again, I think I would have just went with Caterham Schroth belts (assuming they are actually dated). Belts and hardware, my exact setup was around $1500. That does not include the headache of figuring this out and the shipping costs to return stuff that I messed up on by being a bone head. The Caterham belts would have just worked, fit better since they're made specifically for our application AND you still get the gorgeous yellow color that matches absolutely nothing.
  12. I have to imagine a wet sump 7 on non slicks would be fine, but that's based on absolutely nothing. If its in the budget, I would vote dry sump. Not only for peace of mind but it also gets your more ground clearance if that is important to you. Only when I need to check or change my oil do I wish I had a wet sump.
  13. Thanks @CBuff. Are you in an S3 or SV? I'm obviously unsure having never done it, but it seems like the b23a with a snap in would either not fit or be very tight. You are getting at what I was hoping though. I don't need to have the same bracket as the factory harnesses, just any bracket that can accept a 7/16" mounting bolt, right? I think I could do: b24 brackets all around (1/2 inch hole) SR 65L (sleeve for b24) related washers if they don't come with the SR65Ls. I need to pull my seats again to verify, but I already have sub-strap mounts from the factory substrap I think I can reuse instead of the weld on plates, so it should all be a bolt on affair. I am going to email HMS again and see if they can course correct me here.
  14. I am getting nowhere on dated harnesses for this silly car. I ended up returning the Flexis because I was unable to find anywhere they could sell me the proper 5/8" bolt hole brackets and my return windows was almost up. HMS was the only place to elaborate a bit on my situation. They referred to this size as "Lotus brackets" and stated that there are FIA has rules/regulations in place that prohibit the sale of these brackets and they are required to be sewn in. They offered to sew in the brackets; $7 for each bracket and $25 per lap sewing charge. It lines up with what I am seeing - no one can help me with these harnesses :(. As of right now my only options seem to be either pay HMS to make me custom sewn in harnesses (so ~$2XX extra per side) or order from Caterham and hope they have a full 6 point available and that it is actually dated (This might actually be reasonably priced, relatively speaking). Is there is a bushing/reducer solution here where maybe I can replace the giant factory one with something more standard? The bolt going into the car is a regular 7/16th bolt, but its the bushing/reducer that requires the big 5/8" hole. Could I get a 1/2" bracket, and 1/2" to 7/16th reducer, and call it a day? I assume there is a tried and true recipe for harnesses in these cars and I am just missing it. For those that have non-Caterham harnesses in their S3s with tillets, how the heck are they mounted, where did you order from, and did they come with unique mounting hardware? Are they sewn ins with an end plates that have a 5/8" bolt hole?
  15. Thanks I have a few more emails out, including to HMS. Hopefully I can find something. I will update if I figure out what will work.
  16. Well, I went to install my new fancy 2031 dated Scroth Flexi harnesses and discovered that I am an idiot and they make these bolt in end plates in different sizes. The ones I got are 3/8" but the factory Caterham ones are 5/8". I can't seem to find plate that have this large of a hole though. Anyone know where I can get something that would work here?
  17. Thanks for the info - I am going to go with the Schroth Flexi harnesses and bolt in style mounts since it seems we don't need to run "special" harnesses in our cars as long as they are bolt in. The Schroth ASM FE seem nice but I am really struggling to find the sub belt anywhere in stock and I don't think id ever use whatever harness I end up with in a 4 point fashion to worry about submarining. I do like the idea of the big red easy button though. FHR wise, I think I am going to stick with my current Simpson hybrid S. I am not trying to re-invent the wheel. I did see our friends across the pond recommending the work be done at Arch to make the harnesses correct, but i have no idea what they actually do. Maybe I will reach out at some point and ask if they would be willing to share. I will report back if I can find anything out.
  18. I am getting more into tracking my seven and I am going to start participating in time trials as well as (hopefully) attending the USA7s meet at NJMP. This means I have to get dated harnesses, arm restraints, a fire suit, and an FHR device. I actually have the bulk of that list already or on its way, but I am looking to make a few changes. Harnesses Right now I have the standard Caterham harnesses and the sub strap to make it a 5 point. These obviously are not dated so I need to replace them. Before I pull the trigger here, I see companies in the UK sell Caterham specific harnesses, including Caterham themselves. Its not clear to me if those harnesses are actually dated though. I'm not sure how some of these harnesses are "designed specifically for a Caterham" either. I'd also prefer to order something state side for numerous reasons. Can I get any old pull down 6 point harness with bolt in brackets, or will something be weird in the Caterham, like the straps are 50 feet long or something else unexpected that might cause issues? What harnesses do people run here that need FIA dated? I am looking at getting something like one of these https://www.pegasusautoracing.com/productdetails.asp?RecID=34016 https://www.pegasusautoracing.com/productselection.asp?Product=SCH-94530 Then I would also need to get the bolt in style brackets and swap over to those. I actually ordered a set that were one year old so they were 40% off, but they're sewn in brackets with the snap in style so I need to return them Arm Restraints I just ordered these and I think they actually make a lot of sense for our cars (I do enjoy having arms), but I am a little worried about point bys. I am used to giving really obvious point bys which I assume are going to be pretty difficult to do with these. I can probably t-rex a point for a drivers side pass, but not sure about a passenger side pass. A lot of the HPDE organizations I run with do not allow turn signal point bys. Also I am worried the rear wheel fenders will obstruct the view of my restrained point bys as well. Have any of you had issues there? I will know soon enough when I get them in the mail, but I am curious to hear others experiences giving and receiving point bys from a restrained seven driver. FHR Like the arm restraints, this makes sense. Running harnesses, probably a good idea to do what you can to keep your head attached to your neck. I currently have a Simpson Hybrid S from tracking a Lotus Elise with a 3 point belt. Right now, at least with the standard Caterham harnesses, clipping in the rings from the Simpson Hybrid S into the shoulder straps is a real struiggle sometimes, especially when youre running late to the grid. Also, the back of the apparatus hits the seats making it a little uncomfortable. I think I would like to switch to a standard FHR device, but the shoulder strap angle and placement is out of whack on Caterhams woith factory mount points. They supposed to be between 0 and 20 degrees below the shoulders, ideally at 10 degrees and the mounts are supposed to be much closer together. Is it even possible to correct this? What do people do here? Just run at the incorrect angle? If this is a significant hurdle, maybe sticking with the standard mount points and my hybrid S is the best option.
  19. I also use a Motive bleeder on my 420R and my Lotus Elise many times before that. Its pretty darn easy and works great. I agree doing it wet does waste fluid, thats my only complaint.
  20. Thats a great idea. I already want a camera setup for the back of the trailer because I cant see anything behind. People love to get really close (I can see their vehicle's shadows) for some reason. Maybe they're hyper-miling while I get 12 mpg lol. Having a camera inside the trailer would be nice too. Did you mount the monitor in your tow vehicle? Funny you say that, I am almost in the same boat, although I can juuuust squeeze in with the hitch.
  21. I use a hybrid hans with the Caterham 5 point harnesses. I would actually like to get new harnesses eventually so I can use a normal hans for easy or use. The hybrid is a little bit of a pain to get the lower rings clipped into the shoulder harness connection points. I have not been to Summit yet but I would like get out there at least once this year. Which layout do you like most? And which organizations do you run with when you go? Dominion is a bit more a a hike for me, but I am sure I will get there eventually too.
  22. I was very much planning on going but I am not signed up yet. I didn't realize until more recently NJMP requires dated harnesses and arm restraints. I don't have either of those so I probably wont sign up this year unless I get that stuff squared away. Yeah I noticed they do Wonderful Wednesdays and Track Days with Reed Kryder 2x a month. WW is for "Experienced drivers" and I have only been running in novice groups. I could probably run in an intermediate group without issues, but something about attending an event that calls out experienced drivers frightens me. The Reed Kryder events have novice, intermediate, and advanced, so that might be what I go to and work my way to at least intermediate before taking the plunge into Wonderful Wednesdays. Do you go to those?
  23. Yeah these trailers seem to be a whole hobby within a hobby. At the track, I got more people talking about trailers and stuff they want to do to theirs than they would talk about their cars . Mirror is a great idea! This is super cool and now on my radar. Seems like that would be easier to deal with than setting up a tent. That is a really good tip I didn't really think about.
  24. Trying to see where I might bump into fellow 7 owners. Where and who are you all driving with? I am located in Pittsburgh and would love to bump into some other 7 owners at track event. I am a newbie outside of the now defunct PittRace. I just ventured out to Nelson Ledges with Chin Track Days, which aside from cruddy facilities was a really fun lap and I will be going back. Now that I paid the Chin membership fee, I am thinking about attending their event at Summit main on July 4/5th. https://chintrackdays.com/event-details.aspx?q=5ZPP1Gu2V14%3d Anyone else going? Which venues are 7 friendly? I have noticed quite a few don't allow 7s - namely PCA. Chin actually doesn't either, at least in instructed novice according to a post for 2012, but somehow I was able to register and do an event without issue.
