MK Sportscars USA
Club Member-
Prairieville, LA
Se7en
MK Sportscars
TSnuggs42069 started following MK Sportscars USA
2025 is shown on the title. SB100 is your friend in CA.
Draginduster started following MK Sportscars USA
USA 7s crew - I'm listing this here first, and would love to see the car go to someone in this community. If it doesn't go fairly quickly, I'll be publishing it elsewhere - but wanted y'all to have the first crack at her. MK Sportscars RX5 Turbo $42,000 Located outside of Baton Rouge, LA. Built by MK Sportscars USA, car has current registration and title, as well as an NHTSA issued 17 digit VIN. (VIN number 002) Should be very easy to register in most states. Based on the NB Miata drivetrain, she’s been pepped up with a small turbo, that makes her a blast to drive. Very quiet, very torquey, but sneakily fast. Boost is incredibly smooth, starts to build at about 2200 RPM. No sudden surge to upset the car, almost no turbo lag. ECU is managed by a Motorsports electronics ECU. The car was tuned by Alex at Digitune – very, very reputable tuner for the ME ECUs, and a miata specialist. (Great guy to work with by the way) I’d estimate 210 wheel HP. Turbo is limited to 11PSI, could be increased, as there is electronic boost controller installed. She’s quite quick already. 11 PSI is a good safe limit for reliability IMO. The Innovate PSB-1 gauge above the wheel displays both intake pressure and air fuel ratio via a Bosch wideband O2 sensor. Roll hoop can be removed and upgraded to an FIA cage should it be desired in the future, chassis is provisioned for the cage already – ie – they are swappable. Today’s cost is $29,800 for this kit imported to the US. Plus you’d still need a low mileage donor miata, as well as adding the costs and time to refurbish the parts. And then build it…. Car has about 150 miles on her since she was finished. She’s been shaken down thoroughly, and is ready for pickup today. If the buyer wants to add weather gear, wind deflectors, fender guards, or any accessories, I’d can supply and install if desired. Parts were sourced from an NB Miata, 80K on the odometer. Unmodified donor vehicle, was in great shape and drove perfectly. Cold start video here: Cold Start 8 Minute test drive video: Test Drive (Forgive my lack of video editing skills) More pics: RX5 250 Pics Parts replaced with new during the build: Front and Rear Wheel Bearings Axles Pads and Sport Miata Rotors Differential seals, all Differential braces welded to housing Transmission seals, all Upgraded Flying Miata Shifter Rebuild Kit Water Pump Thermostat All engine seals Valve Cover Gasket Timing Belt and tensioner Fuel Filter Lower Ball Joints 949 Racing Clutch 949 Racing 8.8 lb Lightweight Flywheel, perfect match in this lightweight car – like OEM miata engagement New Spark Plugs Detailed Specs: 15 x 7 / 15 x 8 Wheels with Falken Azenis 660 tires, 205/50 F, 225/45 R Innovate WB/Pressure Gauge ME221 ECU Limited Slip Differential Larger Sport Brakes / Rotors Wilwood Front Brakes with stainless braided Goodridge lines on all 4 corners Mintex Brake Pads (Soft) 2” 4 Point Harnesses FIA certified Coil Over Single Adjustable Shocks Odyssey AGM Battery Walbro fuel pump Bosch EV14 640cc Injectors Radian Fuel Rail, converted to return style system 12” Cooling Fan / Oversized 55MM Radiator Front Mount Intercooler Electronic Boost Controller Removeable Headlamps Suede steering wheel included, some pics show leather – I didn’t care for the leather one. SAE bulkhead fitting under the dashboard for a battery tender. Multiport USB charger with voltage display. james@mksportscarsusa.com
New to 7s, just getting started, general questions...
MK Sportscars USA replied to Jenks's topic in General Sevens Discussion
@IamScotticus All of those engines with a Miata tranny will fit just fine in the MK cars... Kinda hope that's why he's asking. -
Give me a call, I'll answer.... Promise I'm not a pushy salesman, but can get you a pretty close estimate pretty quickly depending on what you have in mind. As @CBuffmentioned, @zootnewton bought a turnkey build from me, @Dipdipdoubleflio just received his as well, about a month ago. I think he's pretty happy with his as well. James 225-366-8670 -
Thanks John. Kit price is in the range of $28K, plus engine, ecu, and miata bits needed. Engines are dirt cheap, and you don't really need a terrible amount from a miata - ie, no donor needed, just buy the components you need.
Wanted to share a car I just finished up and shipped to OR. Was sad to see her go, she looked nice in the shop here! She came out great, and is a wonderful ride. MK Sportscars RX5 Vtec Kit Honda K24 engine, stock other than oil pump upgrade, and 40 degree cam gear. 6 Speed Miata drivetrain, LSD, 22K miles on these donor parts. Hondata ecu (still offers an OBDII port) MK has not offered a K24 powered package before. I installed one in my personal car, but required custom headers and a fabricated engine mount. (I do love these engines!) After 2 years of harassing MK, and a bit of design work, we now offer a truly bolt in kit - making what I consider the ideal package for the US market. Moderately priced build, phenomenal performance, bullet proof drivetrain. I only did (2) 0-60 pulls, no roll out, 3.8 seconds. 1240 lbs without fuel. (The cobra leather seats are pretty heavy as well) 240 - 250 flywheel hp estimate. I'm about to put an order in for another shipment of cars, if anyone is looking, I have room for 2 more kits in there! Thanks for taking a look, any questions, let me know. James james@mksportscarsusa.com
It's a 10% tariff with the UK on auto parts. No additional compounding tariffs for aluminum, steel, etc which is quite nice compared to some of the issues I've had with other countries I import from. I had a container of MK kits arrive a few weeks ago, and had to cut a nice check. "The retailers will have already put on a considerable mark up on the price cost price + shipping" This is not true in my case... I just pass the tariff and shipping costs along to the customer. Listed as line items are on the quotes. Not a prayer I can cover the overages with my margins!
New owner came down for a shakedown run and test drive. A touch warm here in August, but we had a blast!
Been busy around the shop here! Sorry for not posting, I prefer the car work vs. the computer work - I'm sure many of you understand. Here's a few more pics of the build, once the container finally arrived. She's been shipped up to NY, and was quickly registered there. Having a 17 digit VIN make the process pretty darn smooth. Have a few more builds in the pipeline, and enjoying every minute of it - they are all unique and challenging in their own way.
Been busy in the shop! A few more pics of the progress. She's officially "done" until my container arrives from MK. About a day of work once the parts arrive. She cleans up quite nicely, and the stripes always make a huge visual impact. Any questions, let me know.
zootnewton started following MK Sportscars USA
Plenty of progress has been made over the past few weeks. Headers arrived and installed. This car will have a carbon muffler, the stainless is just for testing. Of course carbon looks nice, but the biggest advantage is the fact that it won't burn you like the stainless will - I made that mistake after the first test drive... And still have the mark to prove it! The car has now been successfully tuned, and has about 50 miles on her. I used Alex Hickson over at Digitune in the UK (Obviously a remote tune) First time using him and it was a very pleasant experience. Look forward to working with him more down the road. I'm pleasantly surprised how peppy she it, it's a nice balance of power for such a light chassis. My personal car is pushing a lot more power, this was the car I was most anxious to "feel" for comparison. She's no slouch! Seems like it took forever to get the protective coating off the rotors, just so hard to build heat in the brakes. But they are working great now. The only puzzler was that the car would continue to run for 2-3 seconds after shutting her down - but only intermittently, and only after a longer drive. Turns out that if you cut off the ignition while the cooling fan was on, it would turn into a generator as it spun down - keeping the ECU and coils alive. Slapped a 50A diode in there and the mystery is solved. Still have a few odds and ends to finish up here, and a few parts coming in on the next container from MK (Seats, muffler, rear bulkhead, etc) she's quite close to being complete.
Lots of progress made on the car. Been going fairly smoothly - still waiting on an exhaust header from MK which has prevented finishing the bodywork - but it's finally in route! All electrical is finished, all gauges and sensors work. I briefly started the engine over the weekend, using a basemap for the ME360 ECU. No issues there fortunately. Body has been trimmed and dry fit - not too bad though, a small cutoff wheel and a bandfile make the job pretty simple. Interior panels are drilled for final assembly. Rear fenders and boot bin fitted. Fuel fill assembly completed. She's getting pretty close! Windshield and wipers / squirter will be the next step of the build. Any questions, let me know!
Been plugging away here! Received the chassis harness and ECU from across the pond and started getting everything wired. (MK harness, ME360 ECU and engine harness) This car will use the OEM steering controls from the miata - wipers, horn, lights etc. We are also using the MK gauge set for this car, which conveniently integrates indicators for high beams, blinkers, alternator failure, and oil pressure. We will have one stand alone indicator for the CEL. This also necessitated the implementation of a speed sensor on the rear axle. I tacked some small sections of flat bar on the inner axle stub shaft to provide the signal needed. They say you should glue them on, but that doesn't seem like a reasonable attachment method IMO. Added a real oil pressure sensor, additional water temp sensor, and a new bosch knock sensor. The OEM mazda clocks can be used if preferred, even with the aftermarket harnesses. We decided to reuse the hazard switch from the miata - as the double pole switch makes the job clean and simple with no parasitic draw. A single pole switch will leave the battery powered to the flasher, which doesn't draw much current - but 0 seems a lot better. The only wiring left at this point is the dashboard - which will have it's own harness so that it can easily be removed from the car should the need arise for future modifications. A few pics attached for your pleasure....
(11) 6mm allen head bolts to remove the bulkhead panel. All easily accessible. I am an optimist, but I've also never had one of these components fail in all my years of car ownership. Probably shouldn't say that out loud....
Just checked.... 13 lbs of left over wire, plus probably another pound or two of stuff I've tossed. Nice work on the wiring harness build attached!
