Grady
Dallas
Se7en
WCM S2k
Now I just need to install a shift boot. Going to make the surround out of the left over CF from the dash.
Some more progress. Since the stock rear diff was spitting teeth I have replace the LSD with an MFactory one. The seats and center console are done. I have covered the back sides in carpet. The floor I have done in truck bed coating. Placed the seats and seatbelts in to see the look. I am happy with the colors I have picked out. Need to get the center cover installed, seats permanently installed and rear end alignment. Then it will be ready to drive agin.
Ok got everything working. Seats are at the interior shop so can not test the MPH reading yet. Calibrated the Fuel gauge and temp sensor. Wired in Alt out, L and R turn signals. Programmed oil pressure warnings. Still need to wire in oil temp later.
More progress with the keyless system. Have it wired in and working. Removed the breakers and installed 3 fuse blocks. 1 for battery, 1 for accessory and 1 for ignition. The battery shutoff is now a real shutoff and kills power to everything. As soon as the key moves it wakes up and activates the system to go into Acc mode. Now just need to wire in the brake light and get the sensors working for the ECU master so I can do an engine start.
No racing for me. I will track it. Thinking this would be a good one to do some Autocross. Never done that before.
Have the mounting done of the ADU5. Basic power and ground hooked up. Running wires for oil pressure, coolant temp. Need to get all the sensors installed and wired in. But working on the basic programming/layout of the display. Here is what I have so far.
You know. It!
I have the CF on order so I went ahead and utilized my masters I have in CAD design this weekend. This way I can get my layout figured out prior to doing the cutting on the CF sheet. I found some different switches for the lights that will simplify the layout. In removing all the breakers this is going to make the right side empty. This will be a good place to mount the holder for the Garmin Catalyst. Tried to take the picture from where my eyes will be.
I did some measurements below the dash and where I have my seat I think it will be too low for me. Will do some more measuring after the seat is redone and prior to cutting a hold in a $800 piece of CF. Also thinking with it below it may not work with the placement needed for the ADU. This project will be measure a dozen times or more and cut once.
No ECU upgrade plan at this time. When/if I do will probably go with the EMU Black. I really like the MoTec I have in my Evora but probably will not go that route for this car.
Starting off the new year with the dash project. I was able to disable the key anti theft so I got rid of the key it had installed just for that. With that going to redo the electrical and install a key fob, push button start and stop. Get rid of all the mechanical gauges and go with a ADU5 display. Change out the dash to a CF sheet.
The trunk area was just a tank, bare aluminum and the fuel pump/filter. I moved the pump and filter back to underneath and finished out the trunk with some black interior carpet.
Grady started following Lowest miles per year member
I agree!
