Gene_W
Everything posted by Gene_W
  1. Anyone have some photos of plumbing on a wet sump car with no heater? Seems fairly intuitive, but none of the blogs or manuals seems to show a heater delete car. Just want to make sure of routing and placement of temp sensor. thx
  2. Congrats. I am also building a 360R. Maybe just a bit behind you as my adult son and I are only working when he is off work. We are also about to a point where are stymied due to the fact that Caterham did not mount or send our roll cage. Still waiting to hear when it will be here. Don't want to mount stuff then have to take it off to get roll cage on.
  3. I ended up in approximately the same place. Around $7-8K additional. Apparently when the engines came in for the cars in the same shipment, one customs inspector assessed 25% on one engine while another at the same time assessed 15% on the other engine (both 360 engines I think). Ah, government efficiency at work.
  4. Question for the group. Our track day roll cage did not come on the car or with it. According to Josh a mix up at the factory. Regardless, we will not see the cage for a bit. I am wondering what issues I will have or items we will have to uninstall if we just move forward. I have seen in the build guides and some of the blogs that if I put the rear dampers on before the cage that we will have to take them off to install the cage. Any other "gotchas" we should be aware of on the cage side? thanks
  5. Thanks very much for doing this. I hope to be finished with my build shortly after the first of the year and on to the title process. I am now in Kendall County so hopefully the smaller town people will be easier to deal with. Moved here from Houston (Harris County). Having dealt with that tax assessors office on other matters, I can't imagine what a nightmare that would have been. Thanks again for the great info.
  6. QUESTION for the group. We have worked about three afternoons in the week we have had the kit. Almost finished with front suspension/steering. Question relates to alignment. Of course I will have the car aligned professionally way down the road, but as we are buttoning up the front do people recommend trying to do some rough camber and toe settings either by thread count or manual level on the rotors? Maybe some other method or is this a waste of time. Thanks. Few photos of our sequence and where we are now. I am happy with progress. Ran into the same issues with hard to reach nuts, fiddly spacers etc., that are referenced in the various build blogs. I am amazed people are able to do most of this build solo. Having two pairs of hands has been critical to us several times. We are now going to go quiet for a few weeks due to schedules so not likely to get much done over the next 2-3 weeks.
  7. So today was a big day. Semi with crates had some issues getting here, but once it arrived the local wrecker guys got the crates out of the semi and onto their rollback and in a few minutes had them dropped in front of my garage door. Had three large crates. One with chassis and seats, wheel arches(wings) nosecone and other assorted items in the cockpit of the car. Crate two was largest and had wheels, transmission, diff and many boxes of parts. Third crate was engine. Based on advice from Josh we had a couple of drills fully charged to break down crates. One slight frustration was that some of crates had screws, some had roofing nails and some had a mix. So it was impact driver for a bit, then crowbar for a bit and on and on. We used an engine hoist strapped to front cross mounts and two people handling the back end to get the chassis in the garage and placed on jack stands. We unloaded the pallet of wheels, parts etc. and placed items on racks we had prepared for this. We took the top and sides off the engine crate which gave us easy access to the lift points on the engine. Kept the base to place the engine on for the time being, lifted the engine with the engine hoist and moved it to a safe place. We are missing our roll cage, but hey from what I read it wouldn't be a Caterham build unless you are missing some big pieces. Hardest part of the entire process was breaking down the crates and getting them to a size small enough to go in our commercial size dumpsters. We ended up at the end of the day with a circular saw just cutting everything into bite size pieces. Entire process with two people (and a third for a half hour to the get the chassis in the garage) took six hours with a few breaks to talk to people who saw the delivery and came over to talk cars. Kudos to Josh for some good prep advice. I am posting a few pictures of the delivery and unload process. Once I do a bit of inventory of the parts (to see what else we are missing) and rearranging, I will shoot some photos of the garage layout.
  8. Thought I would get a new build topic set up as we are anticipating delivery of our kit this week. This is going to be a father/son build that may take a bit longer than normal due to my son's work schedule. I have read and reviewed many of the posts in the build section here as well as some of the other build blogs, but I am sure we will have many questions. We ordered our kit through Josh at RMC who has been great to work with, but I'm sure we will have constant questions for this group. I will try to post some delivery photos and provide a few photo/video updates as we progress.
  9. Appreciate this thread. Will be very interested in your final process and outcome. I'm about to start a build out in the hill country. Luckily there is no emissions testing in my county.
  10. Thanks, that is good information. Curious whether yours is a completed car or a build kit?
  11. I read the available information the same as Rustler. I think most recent pricing (from US distributors) included the 2.5% existing tariff so kits delivered may have an additional 7.5% which while unfortunate is not as bad as what was originally proposed. This is of direct interest to me also as I have a kit that is targeted to deliver in the US around late summer early fall. Of course the "negotiations" could change or go off track. One thing I have investigated is the possibility of "parking" the kit in a bonded warehouse in England and slowing the delivery. I hope it doesn't come to that since that would be like trying to "time" the stock market.
