jmaz
Everything posted by jmaz
  1. What did you use to maneuver the crates into the garage? Pallet jack?
  2. Thanks! Wise words that I'll keep in mind. The challenges are a big part (probably the main part) of why I want to do this, and I'm looking forward to the process.
  3. I'll be starting the build of my 310 in a couple of months once it shows up in its crates, and one take-away I've gotten from reading build blogs and threads is that it's wrong to assume that the factory did even basic stuff correctly in terms of connecting up the electricals. That sure makes it tough to diagnose problems since my first assumption would be that I screwed up something during the assembly. I'm curious if these issues such as incorrect pin wiring, connectors not connected, etc. are typical or if they're just more apparent because they get mentioned when folks run into problems.
  4. I hope you'll post updates on your progress. I'm interested in any thoughts you might have on which of the many available build blogs and threads are proving most helpful to you. I'll be in the same position in about 2 months when my 310 Encore kit is due to arrive.
