Metal Shaping 101
Here is how I make rear fenders. Using .063 aluminum 5052 or 3003 H-14
-- First roll sheet through rollers to curve ,this way edge isn't doing all
the work.This puts memory into metal,that it will want to go back to.Full arch unnessary,I go about 2/3 of the way.
-- Flatten sheet and brake body flange to 90 degrees.
-- Shrink 2" in on outer edge,then 1" in to finnish radius. While also shrinking body flange.This is what shapes fender arch.
--Use english wheel to smooth radius edge.
5 degree slope on fender means you start with curved, not square blank.so yes its a problem.
Yes! you can do this at home, but most shrinkers have a 1" throat so the radius edge is sharper,the pvc trick is important. Great!! first project, and you can buy a shrinker and do it for about the $250 plus shipping that I will charge for the job. Let me Know.:cheers:
Randy 541 474-1071
This message is Blastolene approved!
