Here are the highlights. Anything not mentioned, just ask!
Motor:
3.4L GM 60 degree V6, 9:1 compression
Crower solid lifter cam, .520 lift, 110 deg cl
1.6 aluminum full-roller rockers
Chromoly retainers/keepers, dual springs
custom hardened push rods
Custom Road Race oil pan, gated & baffled, increased ground clearance
Supercharger- B&M 142ci, 148% overdriven, custom manifold & drive
Holly 390 cfm carb- modified, no choke, slosh control
Mallory Hyfire ignition system, w/ revlimiter (set 6250 rpm), recurved distributor
Holly fuel system
The Rest:
Weight 1560# ready to run (wet, no driver)
T-5 transmission
10 bolt rear, 3.42 gears
Auburn Gear "Autocross" LSD (Dramatic improvement over Torsen- I can't brag enough about this product!)
Added 4-link adjustments
Willwood pedals & master cylinders, bias adjustable
Hawk HP-Plus pads front, rear drums
AVO adjustable dampening shocks w/ 275# rear x 325# front springs
Kirkey low-back sprint seats
Street wheels- WELD 15 x 7 forged w/ Falcon 205-50
Comp wheels- 13 x 8 / 13 x 10 Diamond w/ Goodyear Slicks
Trailer- custom built 12 ft single axle low deck w/ stone guard & 8ft custom aluminum ramps- short & light, tows splendidly!
Parts: everything that came with it or was changed since I've owned it
