Monte Busa Posted January 5, 2015 Share Posted January 5, 2015 (edited) In the process of upgrading / rebuilding the engine in my S3, I have accumulated a fair amount of parts. Since K Series lumps are not that common in the States, I don't know how much items will be worth, but thought I'd offer them here to see if anyone is interested before they go to the scrap yard. The engine was in fine running condition when it was torn down for the rebuild. For sale, best offer: 1.4L K short block, with crank, rods, and pistons installed, otherwise stripped. Stock K head with cam ladder, and valves / seals, otherwise stripped K Supersport intake plenum and throttle body, with bracketry EU2 MEMS ECU and MAP sensor Stock (large body) alternator and bracketry "Purple" dry sump scavenge pump and fittings with some plumbing bits Some miscellaneous bits Location: SE Michigan (Detroit NW suburbs) I'll post pictures if there is any interest. Cheers, Aric Edited January 5, 2015 by Monte Busa Link to comment Share on other sites More sharing options...
Monte Busa Posted January 5, 2015 Author Share Posted January 5, 2015 A few parts to add: - sintered steel cam wheels - Supersport cams for solid followers Link to comment Share on other sites More sharing options...
Monte Busa Posted January 7, 2015 Author Share Posted January 7, 2015 Any takers? If not, the parts are going to the recycler / scrap yard on Thursday! Thanks, Aric Link to comment Share on other sites More sharing options...
yellowss7 Posted January 7, 2015 Share Posted January 7, 2015 Any chance you have a 1.8L VHPD head you're not using? :jester: How did your upgrade to the 1.8L go? Tom Link to comment Share on other sites More sharing options...
Monte Busa Posted January 8, 2015 Author Share Posted January 8, 2015 Hi Tom. If I had a VHPD head, I'd definitely be keeping that! The upgrade build went well - just degreeing the cams and installing the trans before I can put the engine back in its home! Link to comment Share on other sites More sharing options...
