Stimpy Posted May 6, 2015 Posted May 6, 2015 Hello, i have a Super Stalker with 13x10 rear and 13x8 fronts running hoosier r25bs (2500). Does anyone have a suggest starting pressure? 18psi is what i calculated based on my much heavier car.
xcarguy Posted May 6, 2015 Posted May 6, 2015 Stimpy, Contact Scott Minehart (Stalker Autos). (386) 931-6437
Stimpy Posted May 6, 2015 Author Posted May 6, 2015 Stimpy, Contact Scott Minehart (Stalker Autos). (386) 931-6437 thanks. He gave me a good idea where to start, and suggested i "man up" to 10" fronts...
Silk Posted May 7, 2015 Posted May 7, 2015 I autocross a Super Stalker regularly - and some time ago went to 13x10s at all four corners. Much better turn-in! Running Hoosier bias ply slicks, I've found that a few more lbs. in the front seems to work well. I run 19 lbs. in the front and 16-17 in the rear. Also, the bias ply slicks don't like much camber - I dialed back to about 3/4 degree. Used to run almost 3 degrees with Hoosier A6s.
