Complete Heater Assembly from my 2001 Caterham. Still installed in my car as you can see in the pictures but as I just don't seem to ever use it I'd like to sell. Great shape and works perfectly (both fan speeds). Will include the heater ball valve, pull cable, and all braided lines as shown in the pix. $225 firm plus shipping from Akron, OH. Craig. (330) 807-0742 or chima97@aol.com
I believe that it should work just fine. Easy install with a crossflow motor since the plumbing will be essentially identical. Two wires from your rocker "fan" switch (one high speed and one low speed) and one ground wire and that's it. Can give you the dimensions of the heater box unit if you like as well. Craig
