craig chima Posted April 30, 2016 Posted April 30, 2016 (edited) Complete Dry-Sumped, 1600 Crossflow (.030 over) built with very desirable 711M block. On Dellorto DHLA's with 32mm chokes. Compression is 9.0:1 so runs fine on even 91 octane pump gas. 1.53 intake/1.31 exhaust valves and ported and polished head with upgraded springs and Norris 286 cam. Titan dry sump pump and pan. Approximately 130-135bhp. Includes alternator, distributor, clutch, flywheel, very nice 4 into 2 into 1 header/exhaust system (completely Jet Hot coated) for Caterham and also dry sump tank. Pretty much everything you would need to "plug and play." $3500 for all listed above and would prefer to sell everything as a package deal. If someone wants the motor separately, I might sell the exhaust and other bits separately. A la carte pricing as follows: less the tank $3400, less the exhaust $3100, less the clutch and flywheel $3000. Craig (330) 807-0742 or chima97@aol.com[ATTACH=CONFIG]10870[/ATTACH][ATTACH=CONFIG]10866[/ATTACH] Edited April 30, 2016 by craig chima
locost7018 Posted April 30, 2016 Posted April 30, 2016 If no one wants the exhaust system I might be interested. If this package deal had been available a year and a half ago I would have bought the entire package. Russ
