Leoj2006 Posted June 21, 2020 Posted June 21, 2020 (edited) Sold today ! Thank you all for reading my adv't. I told the new buyers about this site, and how informative it is. Sabre Seven (HS Engineering) Car + Trailer + Spares $13,900 Mega professional updates. Was & can be street legal (needs emergency brake). $45,000 invested - my loss = your gain. Receipts available. $13,900 – negotiable. PM me with questions. Car + chassis: 1. HS Engineering Sabre 7 – manufactured 1989 (featured in various kit car magazines) 2. 91” wheel base 3. California car with CARB sticker 4. 1 ¼” square tubing frame 5. Aluminum body + fiberglass clamshell front fenders + fiberglass rear fenders 6. Aluminum cycle style front fenders – fit 10” wide slicks 7. Drivetrain and suspension – Ford Pinto based with full custom racing upgrades 8. Roll cage – professionally built (bolt-in) – SCCA road racing legal for next weight class 9. Tops - #2 with doors 10. Tonneau cover 11. Gauges – all new Auto-Meter (2019) except speedometer 12. Switches & wiring – new Painless Performance (2019) 13. Windshield + #2 Brooklands style wind screens Drivetrain + related: 1. Ford 2000cc 1972 – professionally rebuilt with all performance parts 2. Cylinder head professionally rebuilt – October 2019 3. Race type performance camshaft 4. 10.5:1 compression ratio 5. Dual Weber DCOE 40 carburetors 6. Carter electric fuel pump – new July 2019 + Holley fuel pressure regulator 7. Custom ceramic coated headers + Magnaflow muffler 8. 5.5 quart baffled custom oil pan 9. Accusump oil accumulator – 2 quart with electric on/off switch 10. Oil cooler with integral fan (Derale) 11. Custom radiator with switchable fans 12. MSD 6AL ignition system – adjustable rev limiter 13. Distributor converted to Pertronix electronic 14. Ford 4 speed close ratio transmission – professionally freshened - rebuilt 15. Clutch – new - July 2019 16. Currie Enterprises – custom Ford 8.0” rear end (3.80 or 4.11 ratios) – ok to 300+ HP 17. Detroit Tru Trac posi differential 18. Aftermarket rear axles – big bearings 19. Odyssey battery – PC680 20. Master shut-off switch 21. Fuel cells - #2 @ 5 gallons each (Jaz – aluminum - foam filled) + roll-over valve Brakes + Suspension: 1. Wilwood Dynalite – 4 piston calipers F/R 2. Wilwood dual Master Cylinder 3. Wilwood Proportioning valve 4. Sierra Racing rotors (cross-drilled) + Carbotech pads 5. Coilover suspension – front (custom UB Machine) & rear – custom 4 link 6. Adjustable (single) shocks F/R – Spax 7. Corner weights adjusted professionally + alignment. 8. Custom steering (MGB rack) - with quick release Mountney GT wheel Tires & Wheels: 1. 5 - Carroll Shelby aluminum 14 x 6.5 street wheels & tires 2. 4 – Keizer lightweight 13 x10 aluminum wheels mounted with slicks 3. 15 - steel 13” diameter race wheels (various widths) with slicks or treaded race tires Interior: 1. Seats – Kirkey aluminum high-back (driver) + Corbeau high-back (passenger) 2. Harnesses – 5 point – driver (G-Force) & passenger (Impact Racing) 3. Bulkhead with removable cover between passenger compartment and fuel cells Miscellaneous: 1. Full lighting equipment and switches (headlights, parking, back-up, 4-way) + Horn Trailer: 1. Eliminator by Unger & Wilhelm - custom dual axle – 12’ x 6’ bed; 15’ 9” total length 2. Trailer fits in standard garage – garage kept at all times unless in use 3. Tire rack – holds 8 race tires/wheels + spare 4. Front mounted spare tire for trailer 5. Electric trailer brakes 6. 14” trailer tires for lowered loading height 7. Winch with remote control & custom mount Spares: 1. 2 transmissions – professionally rebuilt & not used (plus parts transmission) 2. MSD 6AL – factory rebuilt 3. Muffler – SuperTrapp 4. Gas tank – original custom – 11 gallon 5. Tire insulation blankets – fit over slicks or race tires 6. 4.11 rear end gear (almost new) 7. Seats – low back (need upholstering) – include adjustable seat tracks 8. Emergency brake handle and cable assembly 9. Miscellaneous new gaskets, seals, bearings, thermostats, etc. 10. Starter – new (NAPA) Recent (2019) service: 1. Cooling system flush and refill (October) 2. Oil and filter change – Brad Penn semi-synthetic 10W-30 (October) 3. Brake fluid flush – Castrol GT LMA (July) 4. Differential fluid (July) 5. Compete professional tune-up – including carburetors (October) More pictures & video upon request. Edited December 5, 2020 by Leoj2006
slngsht Posted December 8, 2020 Posted December 8, 2020 Car is sold. Locking thread per user request.
