JohnCh Posted March 6, 2021 Posted March 6, 2021 We've had a number of request in the past to add a member map, but there wasn't an easy way to do this with vBulletin. With the move to Invision, we had an opportunity to address this with the purchase and installation of Community Map. The map is only visible to authenticated users, so casual web surfers won't have access. If you don't wish to expose your exact town, just pick something in the general area. If you haven't already done so, please go to your Profile and add your brand of Se7en and your location. Both of these fields are exposed on the map, but the map does not use the location field to crate your marker. You must do that manually. A Help Guide is available if you have questions. BTW the "Use Current Location" option is not visible in the test environment even though the software was installed within an hour of production and is the same version. I'm looking into this, but recommend you don't use that option. Although it may work and be accurate for you, some IP addresses resolve to very different location depending on the location service used. Entering your zip code is the better method. -John
