vstryker Posted March 20, 2021 Posted March 20, 2021 With a toddler and a newborn on the way, it is with a heavy heart that I must sell my beloved 7. It started life with a Zetec SVT engine then I swapped it out in 2016 with a full on CSR260 Cosworth motor including the bespoke CSR dry sump system. It is quite a unique combo as there are not many S3 with this setup. This car is very light with an incredible power to weight ratio, it tipped the scales at 1180 pounds wet. It was built to be a quick and reliable car for canyon carving and track. It addresses both fuel and oil starvation with the fuel swirl pot and dry sump system to be as reliable as possible. Suspension is fully adjustable with 3 way coilovers (low, high, rebound) along with adjustable front and rear sway bars. No need to ever smog as it is exempt with clean California title. The telepathic handling as well as the screaming ITB’s are toxic, nothing drives like a 7… nothing. Kinks have been worked out, it is turn key and ready to go. Below are the specs and options: 2005 Caterham 7 Superlight S3 California clean title in hand, Smog exempt no need for smog checks 16,500 miles on chassis, black with white stripes (white sticker stripes can easily be removed) CSR260 2.3L Cosworth engine with CSR 2 stage dry sump system (Bellhousing, swirl oil tower and all), fully balanced, blueprinted. Cosworth everything, CNC machined head, forged rods, forged 12:1 pistons, oversized valves, upgraded valve springs & cams, 7 pound CrMo flywheel, roller barrels. Rebuilt back in 2016, has around 1500 miles since. Please click on link for full build 2016 CSR swap to S3 MBE9A4 fully tunable and open ECU from SBD Motorsports, with USB cable, and base maps 6 speed close ratio transmission, refreshed in 2016 build Front wide track suspension LSD, De Dion rear suspension Nitron 3 way adjustable with progressive springs, valved for Caterham 7’s from Simon at Meteor Motorsports 4 piston AP racing upgraded brakes and vented discs with 13” wheels Tillet fixed back bucket seats, with adjustable rails and 6 point harnesses Quick release momo steering wheel Aero screen with CF mirrors Lots of Carbon Fiber: front cycle fenders, rear wheel arches, instrument dash, nose cone, side sills Fuel swirl pot Upgraded Radtec radiator and fan FIA rollbar, original ARCH chassis 1180 pounds wet with 1/3 tank, corner weighted Spare parts included: Caterham half doors Glass windscreen frame Windshield wipers Softbits Tonneau cover Raceco Titanium muffler (9 pounds, repackable) Asking $52,000 For any questions or more pictures, please email me at vstryker@yahoo.com, or call me directly at (714) 7zero2-4four64, thanks for looking!
vstryker Posted March 20, 2021 Author Posted March 20, 2021 Located in Southern California, with current registration until 2022
vstryker Posted March 22, 2021 Author Posted March 22, 2021 Just to confirm, I got under the car and verified that it has a ZF LSD 3.62 rear end
vstryker Posted March 23, 2021 Author Posted March 23, 2021 Thanks for all the interests, and it is now SOLD @sltous
