TwedleJoe Posted May 7, 2021 Posted May 7, 2021 Spare parts laying around after upgrade. If you think they are worth the cost of shipping, I will be glad to send them your way! Cam Cover - Plastic Caterham Coil Cover - Fiberglass Intake - Aluminum - With Throttle Body Caterham Locked ECU - From 2.0 Duratec - R400 - 210HP Fuel Injectors - From Same as Above Fuel Injector Connectors and Harness - Etc.
Ferrino Posted May 7, 2021 Posted May 7, 2021 Hi - I'm converting an older chassis to 2.0 Duratec power and could definitely use these parts! I will drop you a message.
