Hi.
for Ford 2000 Pinto bell housing with T9,
The fork pin assembly is of the pin, a hardened washer & a short piece of anti-chatter tubing.
Can someone list the order of assembly?
Like,  the fork under the pin head, then the washer then the tube...
does the washer and fork slide over the tube?
How about a pic? I think you are referring to the ball stud for the release fork pivot. I've not seen any with spacers. Usually a ball stud is one piece that just screws into the bell and has a fixed location in the bell. Adjustable ball studs have a threaded washer and jamb nut with a way to rotate the stud.
