Hope all are doing well. Installing the brake system in my 1979 Seven. Using a Hydraulic switch. The only ones I find have a 1/8 NPT (pipe) thread and the 3 way is a 3/8 bubble flare. The MG and spit drawings show the threading right into the 3 way. Not sure if this is correct or what needs to be used to seal it? ie washer, thread sealer, teflon tape etc? Any inputs appreciated.
V
I think this is the correct part. It is not NPT and is bubble seat.
https://www.sportsandclassics.com/parts/british-other/sunbeam/sunbeam-alpine/lucas-hydraulic-brake-light-switch/
I'll add you will have a hard time adapting a male npt to standard brake thread and seats. I'm guessing you are not interested in engineering for a strictly electric switch operated by the brake pedal.
Edited by MV8
MV8,
Thanks for the reply. That will work, ordered it! I plumbed the system already, so rather than plug the hole, I figured I would hunt around for a solution. Google search turned up everything but what I needed, as is often the case. Thanks again,
V
I believe I found it at Moss Part # 560-480. Says tapered seat...
