NSXguy Posted September 27, 2022 Posted September 27, 2022 (edited) Hi All, As title states, i'm after these bits as a kit or parts from my 1600. i'd appreciate any offerings in new/used good working order or recommendations. Cheers, Des. Edited September 27, 2022 by NSXguy
TheDingo8MyBaby Posted September 27, 2022 Posted September 27, 2022 (edited) Not really sure you can buy a kit, but you should be able to piece one together from Burton/Dave Bean. You will probably have to buy/make custom lines. This thread is a good reference (BDR and x-flow should be essentially the same for a dry sump kit) To find used parts, you may want to try apexspeed.com. I would suspect that is a far bigger market for x-flow dry sumps there. Edited September 27, 2022 by TheDingo8MyBaby 1
NSXguy Posted September 27, 2022 Author Posted September 27, 2022 Thanks. Yep pretty much casting as wide a net as I can. With key components in hand I can fab up lines etc. I will check out apex. Thanks for sharing 🤝
