IamScotticus Posted October 31, 2022 Posted October 31, 2022 Hello, I need this: For a COVRAD S7350, common Caterham 90s equipment. The COVRAD company is defunct.
MV8 Posted October 31, 2022 Posted October 31, 2022 If that is a pic of your rad, why does the plug need replacement? A pic of the removed plug or the opening would be easier to figure out. Looks like a flanged, straight thread plug similar to an oil drain plug but it could be npt. I'm guessing 3/8 but a few measurements could narrow it down. A thread pitch gauge may be necessary or if it is for an optional fan temp sensor or switch, check the thread specs.
IamScotticus Posted November 1, 2022 Author Posted November 1, 2022 (edited) The thread is 1/2-20 , depth is 3/8. The pic isn't my car, but same radiator. there are identical plugs at the top and bottom tanks. I am hoping to find a plug from a damaged donor core. brass preferred. Edited November 1, 2022 by IamScotticus
MV8 Posted November 1, 2022 Posted November 1, 2022 A new, similar plug with sae thread can be found from an industrial hydraulics supply. If it were metric thread, a similar plug is available as a replacement oil drain. 1
