Hi,
I'm negotiating the purchase of a 1992 Westfield.  There is an Assigned ID number from the state it was originally built/registered in.  There are also Data Plates indicating the model (92 WSE i-2952) and what appears to be a gross weight plate as well.
Is there a Westfield ID or serial number stamped into the frame somewhere?  If so, what general location could I find that in?
Thank for any help on this,
Westfields from that era should have the chassis number stamped on top of the lower tube located directly in front of the engine.  The i indicates it's an IRS car, not a live axle.  Does that match the information you have?
Cheers,
John
