craig chima Posted August 4, 2023 Posted August 4, 2023 Was doing some shop cleaning and found the shifter, bolt, bushings, and nylon block that are used on a "remote" housing on Ford 3 rail gearbox on original Lotus 7''s. This was obviously a replacement kit that I sourced at some point in time for a Lotus 7 restoration that never got used. The block and bushings are common "wear" items resulting in sloppy shift linkage and "feel." These parts are free providing you pay shipping (will likely fit in a small USPS flat rate box at under $10) so let me know if you can use. Craig Chima, CC Motorsports, (330) 807-0738 or chima97@aol.com
craig chima Posted August 5, 2023 Author Posted August 5, 2023 Henry, thanks for the inquiry but sorry they are on their way to Dave. Cheers, Craig 1
