I've pulled down my Seven S3 gearbox (2000E) for a refresh it was getting a bit noisy.  It was the input shaft bearing but I'm changing them all regardless.  As part of the process, I'm counting teeth on my steel speedo drive gear on the mainshaft.  I only get 6T unless I count sideways.  So I went searching for the correct 7T gear and found this auction:
https://www.ebay.com/itm/194390802014
My gear is identical.  Am I going crazy or is the auction gear only 6T?  If I'm not crazy, anyone have photos of what a 7T gear looks like?  Any leads on a 7T?
Edited by jbcollier
