Vovchandr Posted April 15, 2024 Posted April 15, 2024 3 hours ago, biomax said: Manual was indicating the wrong hole. I've used that excuse before... Glad you got it sorted out
biomax Posted April 16, 2024 Author Posted April 16, 2024 (edited) Seriously this new manual sucks. Not only doesn’t it show assembly of the air box or oil overflow tank, it doesn’t show how to install a LHD throttle cable. All the other blogs are RHD. And where the manual says to do it is WAY too late for a LHD. I had to undo the plenum, some plumbing, and air intake to remove the top of the pedal box. Wish I had been warned to do that earlier. Edited April 16, 2024 by biomax 1
biomax Posted May 12, 2024 Author Posted May 12, 2024 (edited) At the end of April we put in the exhaust header, collector & catalyst. Then 2 weeks of work kept me away. Resumed this weekend with the springs on the exhaust (they suck even with the zip tie hack) and lambda sensor. Today we put in the handbrake and cable. Next up, prop shaft, diff, and whole rear end... In the meantime, still awaiting brackets for my radiator, positive & negative cables for the battery, as well as the proper steering wheel and LED headlamps (they send a quick disconnect shaft with a standard wheel, and regular headlamps when we ordered LED). Edited May 12, 2024 by biomax
TN_Scooter Posted July 19, 2024 Posted July 19, 2024 Watching this build closely, waiting on my 7. My build date is the end of this month. Really interested in seeing what issues may pop up during your build. I'm just down the road in Smyrna, TN. Good luck! Please keep us updated.
TN_Scooter Posted August 7, 2025 Posted August 7, 2025 Curious how your build went. Since my last post, I have received/built my 7 and have it on the road. Hope your build went smoothly and you are now enjoying your new ride.
