*Sold* 15in Caterham 10 spoke wheels with tires. Anthrite Dark Silver
These were backup wheels for a track day to make a blow out didn't ruin a weekend.
Never used by me
Square setup. 15x6.5 I believe
Tires are like new in wear but could be aged out depending on what the rule is.
Can drop off in NJ this fall at NJMP 7's event.
Very good condition
Tires are 195 CR500's
$950 w/o shipping. Located in NY
I have brand new center caps for them as well.
Edited by Vovchandr
  • 1 month later...
  • 1 month later...
I'm interested in putting these on my 1991 DeDion - could you confirm the bolt spacing and offset? I know there's some complication about CSR vs DeDion wheels having the same markings but different physical offsets.
Would also be interested to know the tire DOT dates.
Bolt spacing should be the standard late model Caterham which I believe is 4x108
Offset is ET13. CSR has same stamped offset as wheels are the same but the hub face is machined down. These are not CSR.
Dot date if I read it right is 2011
Edited by Vovchandr
  • 1 month later...
  • 1 month later...
2 hours ago, AddLightness said:
Hi There. Question regarding age of the tires. What is stamped on there or do you recall the date of purchase?
Stamp reads 2811. I purchased these around 2020 if I recall. They were in California before and basement stable temp through my ownership.
Hi, correct me if I am wrong but my 2014 de dion car is ET 23P.  I always thought CSR used ET 13P is that not the case?
Your wheel offset should be stamped on your wheels.
Depending on the width and face style your et can vary for the same car.
Csr never had its own made wheel with proper stamped. They machined down existing wheels so their etc is calculated and not stamped. I believe my information in posts above is correct.
Edited by Vovchandr
  • 1 month later...
  • Vovchandr changed the title to *Sold* 15in Caterham 10 spoke wheels with tires. Anthrite Dark Silver
