MV8 Posted December 15, 2025 Posted December 15, 2025 (edited) 40 minutes ago, JWX said: Were pedal return springs originally installed on the brake and clutch pedals for the Series 2 Seven? If so, where did they attach to pedal and chassis? Can’t find any reference in the S2/3 parts manual and there are no fittings on my newly purchased pedals. Regards, John It pulls the clutch pedal toward the floor enough to keep the clutch cable from going slack so the pedal will return to the same position. Attachment is above the pedal pivot to where the clutch master would be. I've not seen a spring on an S2 brake pedal. To hook the spring, a tab from sheet metal or a loop of 12ga wire can be bolted on to the master bracket. Edited December 15, 2025 by MV8
IamScotticus Posted December 17, 2025 Author Posted December 17, 2025 I believe most S2 were hydraulic clutch. Do those require a preload spring?
MV8 Posted December 17, 2025 Posted December 17, 2025 The spring inside the clutch master must be sufficient with no cable friction to overcome.
JWX Posted December 17, 2025 Posted December 17, 2025 Thanks for all of the replies regarding pedal return springs on the S2. Yes, hydraulic clutch for a 2000e gearbox / twincam installation. I prefer having secondary return springs for pedals, probably an unnecessary habit left over from racing, so will figure something out. Regards, John
