Any suggestions on how to install this thing? Brute force doesn’t seem to work.
Protect the parts and use a lever to press the bar in.  I tried this, as my SB is presently detached.  I found if I pressed in then pushed the bracket down, I can finger the bolts in the bracket
There appears to be a spring in the socket putting tension on the ball.  I am curious if this tension is necessary?
Edited by IamScotticus
  • 3 weeks later...
I struggled with it.  Destroyed one (maybe two) of the ball end pieces.
What finally did it was:
1. Tons of grease on the ball end pieces and a little in the sockets.
2. Put one side in its socket.  Driver side in my edited version of IamScotticus's pic.
3. With a rubber mallet, hit hard where shown in my edited version of IamScotticus's pic, towards the middle/driver side/side that is in a a socket.
