Smithengineered Posted March 10 Posted March 10 Caterham Seven speedo with 2419 miles and in excellent condition! With bracket. Does not come with harness. $225 plus shipping Skydrive GPS Electronic Speedometer interface $185 plus shipping.
Smithengineered Posted March 14 Author Posted March 14 If purchasing both together I can do $350 plus shipping.
Daniel Escobar Posted March 18 Posted March 18 Didn't know this was possible. Good luck with sale, but can you share some info? Did you make a connector to the speedo? Need this on my car!!
Smithengineered Posted March 19 Author Posted March 19 On 3/18/2025 at 10:50 AM, Daniel Escobar said: Didn't know this was possible. Good luck with sale, but can you share some info? Did you make a connector to the speedo? Need this on my car!! If you are running an electronic Speedo it can be wired directly into your existing harness that plugs into the back of your Speedo. It just requires a speed signal, constant power supply and a ground.
Daniel Escobar Posted March 19 Posted March 19 3 hours ago, Smithengineered said: If you are running an electronic Speedo it can be wired directly into your existing harness that plugs into the back of your Speedo. It just requires a speed signal, constant power supply and a ground. Thanks!!!
