Caterham Seven speedo with 2419 miles and in excellent condition! With bracket. Does not come with harness. $225 plus shipping
Sold- Skydrive GPS Electronic Speedometer interface $185 plus shipping.
Edited by Smithengineered
Didn't know this was possible. Good luck with sale, but can you share some info? Did you make a connector to the speedo? Need this on my car!!
If you are running an electronic Speedo it can be wired directly into your existing harness that plugs into the back of your Speedo. It just requires a speed signal, constant power supply and a ground.
Thanks!!!
  • 4 months later...
So do I understand correctly that this Speedo/SkyDrive combo means that the speedo will work (using GPS speed) regardless of mechanical connection to the drivetrain?
