Wanted: Birkin S3 engine mount brackets to fit Ford Kent 1600.
I recently bought  a 1999 Birkin S3, complete save for engine. It had a Kent 1600, which I am trying to find, not very easy in the US. It is also missing the engine mount forks. This is my first 7, at my advanced age it will be the last, but it is a well turned out car. Also looking for a QD hub for the steering wheel, getting in and out isn't a graceful process, though onlookers would get some amusement observing.
The car has a lightweight flywheel, tubular headers, oil cooler, 15 inch Panasports, looks like Honda brakes. It'll be a lot of fun on the twisty two lane roads that wind around the lakes and hills of New Hampshire, USA.
Thanks in advance,
Mike
Mike I have most of the parts for a stock 1600 cross flow build or I can make you a snotty 1700 cross flow.
Stock cast iron  heads or modified/ ported dual spring in both iron or aluminum .
Dual Weber carbs, manifold  and air cleaner or stock GT.
let me know what you need.
can sell parts or build to your Specs.
can deliver to the Lime Rock Festival next month if timing works out.
Chris D
585 330 5456
  • Thanks 2
Chris, I texted you a bunch of photos of my Birkin, they are from 603-677-2776. I hope they got through.
Mike
