Timothy Keith-Lucas Posted 15 hours ago Posted 15 hours ago Could someone with this stuff in their head tell me the specification for the brake shoes for a 1962 Series 2 America? They appear very ordinary, but as usual the parts dealers name the more common cars that use them but not the Lotus Seven. Thanks.
IamScotticus Posted 1 hour ago Posted 1 hour ago (edited) Tim, you have to go to the Triumph guys for the car that used the 7" (Stanpart) Standard 10 ,TR 10, Herald axle and shop for those parts. Tony wheel writes, "The series 2 use the cheaper but similarly sized axle from the standard triumph, eight, ten and companion range of cars , which was almost out of production by 1960. Axle supplies, though , lasted for another eight years." If that is what you have. Rear brakes may have been changed out to suit the 7 and another owner may have so checking that is something. I reccomend pulling a drum and measuring the inner diameter and brake shoe width. Get any part numbers off the shoes, drum back plate, drum, and axle. An interesting factoid, a Standard 10 axle from the 60s still has a lot of part interchangeability with the Ital/Marina axles of the 80s. I will look for the info for the Triumph Standard 10 brakes. Another thing, what you find will not likely have the correct shoe compound. Shaving down the middle of the shoes may help prevent lockup. Here is a relining specialist https://porterfield-brakes.com/manufacturer/brake-shoes/ From Tony Weale Per Weale, rear brake shoe PN for 60-68 S2 Standard Axle is "MGR21", which may be an early Caterham catalog PN. Per the Caterham Lotus 7 S2,3&4 Service Manual reprint, Section J 10, Rear shoe PN for "M.S.1"= "120131", which may be for S1 Metropolitan axle. Then M.S.3 =8260. Unfortunately in the illustrated key to axle components list, he brake shoe PN is not listed, sec H 5. But it would be a Lotus PN. I will update this post with new info. Edited 9 minutes ago by IamScotticus
