southwind25 Posted November 5, 2007 Posted November 5, 2007 where in the USA does someone find a T9? is there a substitute?
locost7018 Posted November 5, 2007 Posted November 5, 2007 I have a T9 from a Merkur with bell housing, prop shaft, used clutch and p-plate that I bought to use in my Locost and now my plans have changed. You can have it for $200 plus frt if you are interested, Russ
Robert O. Urfer Posted November 5, 2007 Posted November 5, 2007 There are many Merkur enthusiasts in ohio and especially near akron. Check out merkursport.com or merkurclub.com and you should find what you are looking for.T9 trannies as far as I know were only used in the merkur here in the states. I upgraded my Merkur when I had it,with a T5 which is much stronger and not much heavier if any.
