I'm dangerously assuming that since most of the car was sourced from someone else's parts bin so were the suspension bushings.  Is there a list of the original application for each rubber bushing?
I copy info I find on the net, use at your own risk. Some of this may be incorrect.  But I try.  I have not seen a complete list of the donor vehicles.
BUSHES GENERAL
Y16 (tapered)Front Suspension Link Bush
AUSTIN FROGEYE SPRITE
MG MIDGET & 3000
equiv: MRM220
03471R
MGB
AH SPRITE MK3
AH 3000 MK3
AH SPRITE MK4
CROSS REF:
2A4027
2A4163
330-520
88G274
Rover 88G274
Length: 17mm
Wide end diameter: 29mm
Narrow end diameter: 23mm
Centre hole diameter: 12mm
Fitment to wishbones and anti roll bar (8 per car)
MOSS pn 330-520
Y9 (Tapered)Control/Trailing Arm Bush
EAN# 5016593126077
Cross Ref:
Rover 8G621
281-405
MG Midget 1/64-12/79
MG MGC/GT 1/67-9/69
MGB all
TAXI FX4 1/59-12/89
TAXI FX4R 1/82-12/85
ROVER A60 CAMBRIDGE 1/62-10/69
AUSTIN HEALEY
BN 1&2 53-56
BN 4&6
SPRITE MK3 3/64-10/66
SPRITE MK4 3/66-10/71
3000 MK3 3/64-10/71
Length: 23mm
MOSS pn 282-305
636 (B636/2)
Length : 3.5mm (1 3/8")
Total diameter : 2.7mm (1 1/16")
Opening diameter : 1.3mm (1/2")
B636/2 Short (S636/2A)
Internal diameter: 13mm
External diameter: 27mm
Length: 26mm
B6362 Short (B*636/2A)
Length: 26mm
*same as S636/2A with a "B". Typo?)
RB636/2
Wishbone, A frame, Radius arm
Internal diameter: 12mm
Length: 34mm
BP636/2
Top Link Peened
Total diameter : 2.9mm (1 1/8")
E2030
Radius Arm Small
Length: 31mm
Centre hole diameter: 9mm
Outer diameter: 19mm
E2030 Short (S2030A)
Length: 26mm
Centre hole diameter: 10mm
Bush Eyelet Front (E4-B46-608C)
35MM
Steering Column Bush (B8466)
Caterham suspension Bush Kit Live Axle (BU03K)
@IamScotticus has supplied a very comprehensive list of types and sizes for a Caterham and Lotus Seven.  The original bushes sourced by Lotus were produced by a company called Metalastik (sometimes spelled Metalastic).  As noted on the web it is: "A famous historical British brand of rubber-to-metal bonded components, including flexible bearings and bushings founded in Leicester in 1937 by engineer Mac Goldsmith.  The brand is now owned by Trelleborg, and distributed in the U.K. by Robush"
A number of road and racing car manufacturers relied on Metalastik rubber and metal bushings for suspension, engine mounts, gearbox mounts etc.  Lotus as well as many other car manufacturers made use of them as shown on Scott's post.  Caterham still shows a few for sale on their web site, but check to see if they are metric, before ordering for an early Caterham (which may still  have used Imperial sizes), or a Lotus Seven (which definitely did use Imperial).   W
  • Thanks 2
