xflow7 Posted August 31, 2006 Posted August 31, 2006 (possibly only live axle cars). Since my car was repaired and they re-installed the inner panels in the cockpit the driver side panel edge overlaps on the outisde of the aluminum foot box as seen here: >http://tinyurl.com/ko53n You can see the unused holes at the very forward edge. There do not appear to be holes behind these that it would have been fastened to (presumably why they did not rivet that edge. I can't remember for certain how it was pre-repair, but I have a hunch the interior side panel should be between the aluminum footbox and the frame. It's not too big a deal, but my foot occasionally catches the exposed edge as I come off the clutch and I don't ever remember that happening before. Can one of you kind souls have a peek down in your Caterham's footbox and tell me which way it should be? Cheers, Dave xflow72006-08-31 04:55:04
stevet Posted August 31, 2006 Posted August 31, 2006 Hi Dave, Mine overlaps the same as in your photo. However there is another small panel filling the space between the red panel (mine are red too...) and the front edge of the footwell - this is on the drivers side only, the passenger footwell looks the same as your pic. I'd never noticed this before, and don't know what purpose it serves - maybe it smooths out the surface there - but my feet don't catch. I'm headed out now, but will try to post a photo later if that helps. Steve PS: mine is not live axle
stevet Posted August 31, 2006 Posted August 31, 2006 Dave - pic attached (I hope). AS you can see, my footwell needs a clefile:///C:/Documents%20and%20Settings/steve/My%20Documents/My%20Pictures/2006-08%20%28Aug%29/seven%20footwell.jpgan!
xflow7 Posted August 31, 2006 Author Posted August 31, 2006 Hi Steve, Thanks for the response. Don't think the picture worked (at least I can't see it here). I'll PM you with an email address you can send the pic to. Thanks, Dave P.S. Go Red Interiors! http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif" border="0" align="absmiddle"> xflow72006-08-31 17:20:59
