Just saw this on the GRM forum and thought it might help, Russ
Taken from MoparChat
Posted for informational purposes only.
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed and the 87-92 Toyota Supra Turbo R154 5-speed all share the same case to bellhousing bolt pattern. As such there are a number of possibilities that can be had when a 5-speed is desired:
94-95 Dakota 2.5L bellhousing: Connects R154 to any K car based 2.2L-2.5L L4 in a RWD application.
94-99 Dakota 3.9L V6 Bellhousing: Connects R154 to any 3.9L V6 and any 273/318/340/360 V8.
96-99 Dakota 2.5L bellhousing: Connects R154 to any Jeep 2.5L L4. Because of it's GM inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8.
88-99 Jeep 4.0L L6 bellhousing: Connects R154 to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
01-03 Jeep Liberty 3.7L V6 bellhousing: Connects R154 to any 3.7L V6, 4.7L V8 and 5.7L Hemi V8.
R154 Ratio’s 1st 3.30:1 2nd 1.95:1 3rd 1.34:1 4th 1.00:1 5th 0.75:1 Rev 3.20:1
The R154 is a particularly robust transmission. It shares it's design with the AX15 but is built to a different spec. Not in the Tremec class, but better than a T5. It would work well in certain applications. The deciding factor to use something like this would probably be cost. Good used R154's can be had for about $300 and bellhousing for about $50. Converting to a hydraulic clutch would add a bit more expense but still, nowhere near the price of a Tremec. So, if you've got a 318 2 barrel in your daily driver, this might be for you. It should be pointed out that Australians LOVE these gearboxes for V8 conversions.
So, this is what CAN be done with stock, boneyard parts. Enjoy.
Greg Williams
More information from TurboDodge
There's your Rear Wheel Drive kit.
87-92 Supra Turbo 5-speed and yoke
94-95 Dakota 2.5L bellhousing, throwout bearing, slave cylinder and fork
94-99 AX-15 Front bearing cover
You'll need a 21 spline clutch disk. Might be able to match up one from a Toyota V6 truck.
Greg
Taken from Jeep-Offroad:
Part I
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed, the Jeep NV1500, the Toyota R150F & R151F, the 87-92 Toyota Supra Turbo R154, the Isuzu AR5 and the Pontiac SolsticeSaturn SkyChevy Colorado GMC Canyon MA5 5-speeds all share the same case to bellhousing bolt pattern (Large Pattern). As such there are a number of possibilities that can be had when a 5-speed is desired:
Pic 1. Novak Enterprises: Adapter plate for AX15 to GM 4-speed bellhousing. Connects all except NV3550 and NV1500 to same.
1.
94-95 Dakota 2.5L bellhousing: Connects all to any K car based 2.2L-2.5L L4 in a RWD application.
2.
96-00 Dakota 2.5L bellhousing: Connects all to any Jeep 2.5L L4. Because of it's GM 60 degree V6 inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8. Also bolts to any Isuzu 3.23.5 DOHC V6, Holden (Australia) 3800 V6 and the LS4 5.3L V8 from the Impala SS.
3.
88-99 Jeep 4.0L L6 bellhousing: Connects all to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
4.
94-99 Dakota 3.9L V6 Bellhousing: Connects all to any 3.9L V6 and any 273/318/340/360 V8, Magnum 5.25.9 V8, 3.7L V6, 4.7L V8, 5.7L Hemi V8, and Jeep 2.8L CRD Turbo Diesel. (Requires use of an 11" flywheel.)
5.
96-04 Toyota Tacoma 3.4L V6. Also works with Toyota 3.0L V6
6.
86.5-92 Toyota Supra Turbo 7M-GTE. Also works with Toyota 5M-GE.
Not shown:
01-04 Jeep Liberty 3.7L V6 bellhousing: Connects all to any 3.7L V6, 4.7L V8 and any 273/318/340/360 V8, Magnum 5.25.9 V8, 5.7L Hemi V8, and Jeep 2.8L CRD Turbo Diesel. (Requires use of an 10.5" flywheel.)
03-04 Jeep LibertyTJ 2.
