Ok Finally got the clutch cable
Evidently its a common prob, they snap in the crimp next to the bajo coupling.
Anyways I have a new cable.
Thanks to Chris at Sevens and Elans in MA (Cat USA r on backorder)
1. in the pedal box lever there are 2 holes, whats the deal there?
2.where the outer sheath with the all thread and 2 lock nuts go to the slave, well is that one nut of either side if the lug that sticks out of the bell housing?
3.Can I do this on my own?
4. any tips here???
Thanks
David
Second hole closest to the pivot is for the return spring.
Both nuts are on the outside, locking the cable length adjustment. I keep a pre-adjusted spare cable in the boot for emergencies, although I've never had to use it.
The skills involved are minimal. It can be done on the hard shoulder in a jam. Just be careful not to drop anything into the lever opening of the clutch housing.
Here's a piccy.
Hi David,
You asked me for pictures of my clutch cable routing a while back. Finally got around to taking a couple. I hope these help.
http://www.usa7s.com/aspnetforum/upload/1343606305_ClutchCable-000001.JPG
http://www.usa7s.com/aspnetforum/upload/398326747_ClutchCable-000002.JPG
Dave
thanks xflow, by the way what temp are you running at, I am just a litttle over 90 C according to the guage.
Cheers
DB
