Sounds like you have one of the Yarwood-era cars. As far as I know he didn’t do anything oddball with his installations, so it should be the same as what the Caterham guys are running. If no one chimes in with a good source, then I’d start with Dave Bean Engineering and RD Enterprises. They can probably help out or steer you in the right direction.
thanks I tried your idea but got no reply from my emails the clutch is a 7.5' disc with a bolt pattern on the flywheel of 8.75" probably a discontinued pinto clutch
Check out this thread. Might be worth contacting Dick Brink, or perhaps PM'ing Southwind25 to see what he finally did for his car.
Email is not the fastest at Dave Bean, I would call them on 209-754-5802 .
Dick Brink is another good option.
I do not think you should have too much of a problem getting what you need.
I have more info .I have now got a clutch.The disc and pressure plate are from a 1973 Pinto and the release bearing is from a Mercury Capri from about 1978 through 1984 . Hope this helps with any future problems.
