JohnCh Posted December 9, 2006 Posted December 9, 2006 I have a new gear lever that is threaded to take an M10x1.5 shift knob. Unfortunately my existing shift knob is threaded for my old M12x1.75 lever. Any ideas where I could get an adapter? I was thinking that perhaps a Time-Sert/Big-Cert or HeliCoil might work, but I've been having trouble finding the outer thread size of the M10x1.5 versions. Thanks, John
slomove Posted December 9, 2006 Posted December 9, 2006 Hmm, not sure if I understand...you are looking for helicoils that can be used on a 10x1.5 shift lever? I have some left over from a project where I made some turned wood knobs for myself and some other fellows. But they were not difficult to find, I believe even at PepBoys autostore. If that is all you need and can not find it locally I can mail you a few. Would to have to lend you the tap and inserting tool, too. Let me know! Gert http://home.earthlink.net/~slomove/sitebuildercontent/sitebuilderpictures/woodshiftknob.jpg
JohnCh Posted December 10, 2006 Author Posted December 10, 2006 Gert, Thanks for the offer. I guess in my attempt at brevity though, I took a detour at clarity. Therefore, I'll bore everyone with the complete story http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif Several years ago I upgraded the gear lever on my Westfield to a Quaife Quick Shift. Unlike the Westfield factory gear lever which has M10x1.5 threads for the shift knob, the Quaife features a beefier shaft with M12x1.75 threads. When I bought that new lever, I purchased a Team Voodoo shift knob and matching handbrake grip. I then had the shift knob laser engraved with the Westfield logo. I recently purchased a gearbox from BGH along with their gear lever extension for Westfields. It is a sturdier design than the Westfield factory extension and requires the use of the modified gear lever they supply. Like the stock Westfield gear lever, it too requires a shift knob threaded for M10x1.5. Unfortunately Team Voodoo doesn't offer a shift knob with that thread size. So I am trying to find some kind of bushing that will enable me to screw my M12x1.75 threaded shift knob onto my new M10x1.5 gear lever. I thought that a Time-Sert or HeliCoil for an M10x1.5 bolt might work, but before I buy either of those I want to find out what size hole (diameter & thread pitch) they require. I'd hate to buy one only to find out that the M12 hole is still too big. If I can't find an off the shelf solution, then I need to find a machine shop with reasonable rates. (yeah, like that is going to happen http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif ). -John
slomove Posted December 10, 2006 Posted December 10, 2006 The 10x1.5 helicoils I used have an outer diameter of 12.25 mm. I guess that should work. A machined adapter may not be feasible because there is no wall left with 12mm outer and 10mm inner thread. I guess the easiest solution would be either - to re-tap your threads with the helicoil tap and just live with the cross-threaded result (probably still ample strong) - to ream out the knob thread to 1/2" and insert the helicoil with epoxy glue using the insertion tool or a 10mm bolt (wrapped with teflon tape for removal). - combination of both above, i.e. re-tap and seat the helicoil with epoxy. That is what I did for above mentioned wood shift knobs. Gert
JohnCh Posted December 10, 2006 Author Posted December 10, 2006 The 10x1.5 helicoils I used have an outer diameter of 12.25 mm. Thanks Gert! I'll pick up a HeliCoil kit and do the retap and epoxy as you suggest. -John
