slngsht Posted May 25, 2009 Author Share Posted May 25, 2009 rob, what do you mean by another notch at the end? Link to comment Share on other sites More sharing options...
slngsht Posted May 26, 2009 Author Share Posted May 26, 2009 New bracket... I do still need to space the heim a little bit so it won't have interference from the bracket. Link to comment Share on other sites More sharing options...
solder_guy Posted May 26, 2009 Share Posted May 26, 2009 rob, what do you mean by another notch at the end? You know .. the rack has notches in which the pinion gear interacts .. when it gets to the last notch .. it has hit the limit of the turning radius. Rob Link to comment Share on other sites More sharing options...
TheDingo8MyBaby Posted May 27, 2009 Share Posted May 27, 2009 You know .. the rack has notches in which the pinion gear interacts .. when it gets to the last notch .. it has hit the limit of the turning radius. Rob Actually, the limit will comes from the iner tie rods hitting the rack. Manufacturers usually cut a few extra teeth in the rack so that it doesn't marr the gear. You may be able to add a lock washer or two between the inner tie rod and the rack to gain some steering angle. You just want to make sure the ID of the lock washer fits on the thread and the OD isn't bigger than the steering rack OD. On my corolla it's 14mm lockwashers. Link to comment Share on other sites More sharing options...
