catracer Posted July 13, 2009 Posted July 13, 2009 (edited) Cleaning these out. Paypal, cash or check. 5% Va sales tax applied if picked up here. Large items may be impossible to ship UPS/Fedex or cost silly amounts. I will not ship wings/noses or side skins please plan to pick those items up here. Call or email with any questions (chipATgt-classics.com) Chip Bond GT Classics Barboursville, VA 22923 1-877-722-3007 (edited to correct headings) Qty descript BODY PARTS 3 LF yellow wings clamshell $221.00 N 5 LF Green wings “ $221.00 N 3 RF yellow wings “ $221.00 N 4 RF Green wings “ $221.00 N 3 LR yellow wings $160.80 N 3 LR Green Wings $160.80 N 3 RR yellow Wings $160.80 N 4 RR Green Wings $160.80 N 1 Yellow Nose cones $239.81 N 0 Green Nose Cones $239.81 N 3 RH Side Skins $386.75 N 3 LH Side Sins $386.75 N 0 Boot Skins $0.00 N 2 New Caterham velor seats $552.50 N 1 Corbeau Elise race seat, driver 665.25 U 1 Corbeau Elise race seat, passer $487.50 U 1 Caterham boot cover, $165.75 N 2 CaterCarbon front cycle wings $338.53 N 2 cycle frt. wingstays $106.08 N 3 flared frt wingstays $72.05 N 1 Rear tail lamp $26.52 N 2 Backup lamps $17.68 N 1 LH Formula mirror flat black $36.00 N 2 RH formula mirror convex black $36.00 N 1 LH formula mirror Carbon convex $65.00 N 1 RH formula mirror flat black $36.00 N 3 LH White formula flat $35.00 N 0 Caterham screen mount rearview $22.10 N 1 7 grill $66.30 N SUSPENSION 2 Caterham LHD steering racks $508.30 N 4 Widetrack front upper wishbones $134.99 N 6 Widetrack front lower wishbones $279.81 N 4 Steering rack rod ends $19.80 N 1 Top ball joint $29.88 N 1 LH upright bare $199.94 N 1 RH upright bare $199.94 N 2 RH steering arms $65.20 N 1 used front sway bar red $125.00 U 3 rearward watt link short $46.41 N 1 forward watts link long $49.73 N 1 rear sway bar blue $100.00 U 1 DeDion bearing housingw/bearings$116.03 N 2 forward DeDion radius arms not Watts $55.58 N 6 front wheel spindle spitfire $8.84 N 2 steering column U-Joints $62.39 N 4 Sway bar plastic balls $4.42 N 6 front sway bar rubber boots $6.63 N 1 inner steering column 2/pc (bolt on wheel) $143.65 N 12 Front bearing kits 1 ea. $9.00 N 4 Rear hub bearing kits 2 ea. $99.45 N BRAKES 16 9" brake disks $59.89 N 1 RH front 9" caliper $276.25 N 1 LH front9" caliper $276.25 N 1 large race master cylinder $220.16 N DRIVELINE 2 driveshaft Ujoints $18.79 N 3 Ford throwout bearings $79.45 N 1 Accusump elect valve $100.00 N 2 Accusump clamps $12.00 N 1 rubber trans mounts $30.94 N 1 alloy solid trans mount $53.04 N 1 Zetec set L& R steel engine mounts $105.00 N 1 USED Diff cores 3.92 ratio $300.00 U 3 USED T-9 transmission cores $150.00 U 1 New Ford crate “field dress”engine 2002 focus $950.00 N 2 Race Clutch Disk $84.00 N 2 Street Clutch disks $45.00 N 3 Ford Front O2 sensor $75.00 N 1 Quaife Close ratio straight cut 2.040,1.540,1.210,1000.0930. Race transmission syncros,no bellhousing, stock Sierra shifter less than 20 miles. $1500.00 U Exhaust 2 Burns stainless collectors, 2006 race $250.00 N 1 USED complete race exhaust, 2005 season burns collector$ 700.00 U COOLING 2 Caterham elect cooling fans $101.66 N 3 Silicone 90's $35.00 N 3 Silicone 135's $35.00 N 8 Radiator vibration mounts $3.00 N OTHER/MISC 1 Spa Memory tach $185.00 U 3 Master disconnects $35.00 N 5 Cat 7" deck badges $26.52 N 3 16 valve" Cat nose badges $17.13 N 1 New Caterham heatercase cracked$165.75 U 1 USED lot Fireblade hubs/axles/brakes rear tube axle (from tube axle) $200.00 U Edited July 13, 2009 by catracer
Boxologist Posted July 19, 2009 Posted July 19, 2009 Chip, as soon as everything is sorted w/ Al i'll need some spare and back up parts.
MichaelD Posted November 13, 2010 Posted November 13, 2010 Chip, Do you still have a set of front wings?
catracer Posted November 16, 2010 Author Posted November 16, 2010 Hi Michael. This list is quite old, but there are many items still available. Of note, the T-9 stuff is all gone. The only fiberglass left are green front clamshells. I'll update after inventory the first of the year. Sorry haven't been checking in much as of late. Been swamped in the shop since January. Cheers Chip
