Plywood 7
catracer
Anyone know anything about a Scottish manufacturer that built marine grade plywood 7's? Have a local customer that bought one from ebay a couple years back. Needed a ton of wiring ( well, complete rewire actually) and some suspension work. Ply body on steel ladder frame. Pretty well executed I thought. Aluminum clad over the plywood. Crossflow with a T-9 and four link solid axle.
Ran great. Just curious.
Chip
Sounds like it might be a BWE Hornet.
There was another that comes to mind (the Locust) but I believe the Locust was of full timber construction (chassis too!) whereas the Hornet just had plywood panels over a steel chassis, with a thin aluminum cladding like you describe.
Edit: Found a little info on the web. Is this the car? --> http://www.locust.org.uk/ownerscars/overseas/quintin_congdon/quintin_congdon.htm
Edited by Innominatus
Add'l info
