oil leaking from the distributor shaft
Is there a seal I should replace?
On my crossflow there is a leak from around the distributor.
Thanks for the advice
Pretty sure there isn't.
I'd be more curious why pressure is driving oil out, maybe you want to look at your breather/vent configuration.
