edcetera Posted March 25, 2007 Posted March 25, 2007 Hello A bit of measuring help if you please ? referring to the picture on the following link I cobbled up... >where to drill I need to know X1 and Y dimensions as show I have a new scuttle and need to poke some holes and need to know where to drill, plus minus 1/16" or plus minus 1 millimetre will do. Thanks so much for any help in this endeavour. Sincerely / Ed edcetera2007-03-25 10:37:40
yellowss7 Posted March 25, 2007 Posted March 25, 2007 Ed, If you're looking for the distance from the front of the scuttle to the center of the first bolt on the windscreen stanchion, and then the distance between the two bolts, on my standard sized Catherham X1 is 47mm and Y is 140mm. Tom
edcetera Posted March 25, 2007 Author Posted March 25, 2007 Ed, If you're looking for the distance from the front of the scuttle to the center of the first bolt on the windscreen stanchion, and then the distance between the two bolts, on my standard sized Catherham X1 is 47mm and Y is 140mm. Tom Hello Tom http://photoed.digitalphotochat.com/SevenParts/abw I only need the X1 dimension and the Y dimension as shown in the picture above Thanks / Ededcetera2007-03-25 14:59:54
yellowss7 Posted March 25, 2007 Posted March 25, 2007 Then I the figures I gave are what you want. http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif Tom
edcetera Posted March 25, 2007 Author Posted March 25, 2007 Hello Tom Thanks for your help but I need both X1 and Y dimensions I already knew the X distance between the holes its 5.5 inches (140mm) Please look at the picture and re-read the question http://photoed.digitalphotochat.com/SevenParts/abw heres a new picture with less clutter http://photoed.digitalphotochat.com/SevenParts/aby Thank you / Ededcetera2007-03-25 17:10:42
