Interesting drawing indeed, noticed that you have made the front susp mount tubes parallel. Which is very efficient for wishbone mounting
But doesn't that alter the entire appearance of the front section, as the taper angle of the ali paneled bits meets the nose cone in a no longer continuous line ?
Can the drawing be a bit larger?
Sadly my eyesight isn't as good as it used to be :-)
Send me an e-mail and I will send you a PDF file of the frame model.
As for the side pannels fitting to the front, if you shape the aluminum to the tubing and round the lower edge of the skin pannel it will look nice and smooth as you can see in the attached photo. Just takes sometime to shape the aluminum to be rounded instead of squared off.
