Another interesting thing I noticed about my early Westfield Seven, The center of my rear axle / drive shaft is offset to one side in the tunnel. Is this normal? Looking at pictures of other Sevens on the internet I found another car similar to mine that seems to be the same way. Would love to hear some input about this.
Darrell
  • 1 month later...
Sort of.. Depends entirely on what Make/intended use of the donor axle.
Some were made so that the required offset was as little as 3/4".
Others have a 2" (or more) offset.
It's dependant on the maker's decision to use equal length drive shafts... Or Not :-)
You would have to identify which axle they inserted into that early westie.
