squarefour Posted November 8, 2011 Posted November 8, 2011 I can't believe the number of times I've seen those little Harbor Freight winches put to cool use. I also saw one being used to deploy the "landing gear" in Don Vesco's old Land Speed Record jet bike, but this use is a close second for coolness!
scannon Posted November 8, 2011 Author Posted November 8, 2011 I can't believe the number of times I've seen those little Harbor Freight winches put to cool use. I also saw one being used to deploy the "landing gear" in Don Vesco's old Land Speed Record jet bike, but this use is a close second for coolness! The winch didn't come from Harbor Freight. The smallest they had was about twice the size and weight of this one. I found it on Amazon.com. It is made by Neiko.
MichaelD Posted May 29, 2013 Posted May 29, 2013 (edited) Skip, How are your shoulders today? What to rent the butt wench? I have a torn right cuff and it does make entrance and egress from a Seven a bit uncomfortable. Track days are a bear. Surgery set for August. Edited May 29, 2013 by MichaelD
scannon Posted May 29, 2013 Author Posted May 29, 2013 Michael, The shoulder is doing well enough that I am putting off the joint replacement surgery indefinitely. Not as strong as it needs to be but with the butt extractor I can still drive my Se7en. It was easy to make and install and didn't require any new holes or other modifications to the car. I highly recommend it. I have stopped doing track days because I am leery of doing further damage to the shoulder and forcing me to have the joint replacement. Skip, How are your shoulders today? What to rent the butt wench? I have a torn right cuff and it does make entrance and egress from a Seven a bit uncomfortable. Track days are a bear. Surgery set for August.
