I bought a nice light weight cover for in-the-garage-usage on my 7 from California Car Covers:
http://www.calcarcover.com/how_to_select.aspx?gclid=CMbrnKn94o4CFQPrYgod-R0dQQ
They have a wide variety from $$ to $$$$, depending on how much protection you need...everything from dust in the garage to anti bird crap outdoors!
It's cut for the 7 and fits nicely with elastic at both ends to snug it down.
Hank
I used my MINI Cooper S cover when I was forced to park the S2K outside for a couple of days. It fit almost like it was made for it as the elastic came tight right at ground level. Even kept the curious local cats out.
thanks Hank, Do you know if a 7 cover fits a CSR?
Thanks
Paul
Sorry for the delayed reply, Paul.
I "think" it would cover most any iteration of the 7. Mine is a bit "baggy" around the sides, so wider fenders ought to be no issue. Also, there is a nice elastic stretch band both front and rear to help with a wider beam. It is more than long enough for my 7 and actually droops down into the passenger area after passing over the stock windscreen.
I have the light weioght "dust cover" style for in the garage, but any off the fancier bird poop resistant model are cut to the same outline.
Hope that helps.
You could call California Car Covers and compare your dimesions to what they have listed for their unit.
Good luck,
Hank
