ERNSTEVERYTHING Posted October 10, 2012 Posted October 10, 2012 Hi, Thought I would ask, as the Raceline seem to be the slackest most useless company. Need a new gasket for my sump... Thanks Anthony
JohnCh Posted October 10, 2012 Posted October 10, 2012 Are you sure it uses a gasket? I have their wet sump for a Duratec and it uses liquid gasket. I thought the design for the Zetec was similar? -John
ERNSTEVERYTHING Posted October 11, 2012 Author Posted October 11, 2012 Are you sure it uses a gasket? I have their wet sump for a Duratec and it uses liquid gasket. I thought the design for the Zetec was similar? -John I removed a Rubber gasket (seal) when taking it apart. I need a replacement.
JohnCh Posted October 11, 2012 Posted October 11, 2012 I just looked at the mounting instructions on Raceline's site (see bottom of this page). It states: 8) Insert standard Ford sump gasket into machined groove in sump, ensuring that it is seated and located correctly. -John
ERNSTEVERYTHING Posted October 13, 2012 Author Posted October 13, 2012 I just looked at the mounting instructions on Raceline's site (see bottom of this page). It states: -John John, I should probably, read more.. thank you Anthony
